2.8 v6 rough running - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2010, 09:24 AM
Have a 88 camaro 2.8 v6. Just replaced spark plugs and wires and have a new engine vacuum solenoid, after new plugs and wires car crunk and idled smoothly for a few minutes then went back into running rough. Car sat for over a year and ran well before it was parked,now trying to put back on road. Any help is appreciated.
Old 07-02-2010, 12:08 PM
Rexnfx's Avatar
Sounds almost like it runs good when in open-loop. Open-loop is logic used to run the engine with little/no inputs from various sensors.
Once it warms up a little it will go into closed-loop. That means the computer will use information from various sensors to run the engine.
It would seem possible that one of the sensors is skewd and not giving correct info to computer during closed-loop operation. I've had O2 sensors do this. But thats a BIG guess without doing any actual tests, or checking the basics. Just had a car with a single wire O2 that was bad. But it actually turned out to be the computer's opamp was defective, telling the O2 to read wrong. So bad computer there...Fun Good luck
Old 07-03-2010, 02:44 PM
Could a bad pick up coil cause it? Could the o2 sensor be messed up by havin a bad egr valve?
Old 07-03-2010, 06:20 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Best place to start is to retreive the codes from the ECM.
Engine running rough Goat67 Engine 8 12-29-2009 11:42 AM
Chevy 2.8 V6 help poolboy Introduce Yourself 1 09-05-2007 05:04 AM
1988 Corsica running rough. 51studebakerpickup Engine 4 04-29-2005 04:54 PM
2.8 litre v6 jackflash Electrical 3 10-05-2004 02:38 PM
2.8 v6 valve adjustments esutton_70114 Engine 0 09-29-2002 07:41 PM
