2 barrel adapter to 1 barrel intake? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-29-2008, 08:54 PM
i have seen 2 barrel adapters that fit a 1 barrel intake i would like to put one on my 300-6 has any body done this? how well did it work? is there an adapter that will be a direct fit for motorcraft 2 barrel off a 73 ford 360
Old 10-29-2008, 09:59 PM
I used an adapter to put a Carter 2-bbl from a mid-60's Dodge 273 V-8 onto a '69 Nova 230 I-6 intake back around 1971 or so. It ran fine, and might have made a small increase in power, but not much. It did have the factory stock exhaust on it, so it might have done better with less restriction on the outgoing side. I swapped in a 283 w/4bbl and twice-pipes, and that worked much better.
Old 10-30-2008, 07:17 AM
FEDDO's Avatar
fordsix.comhas the answer for you. I did this to a 200 with the h/w 5200 carb and got better gas mileage ,along with better driveability.
FEDDO's Avatar
fordsix.com has the answer for you. I did this to a 200 with the h/w 5200 carb and got better gas mileage ,along with better driveability.
Old 10-30-2008, 08:06 AM
Wiki Edits: 31
I also run an adapter for the 2bbl holley 2300 on my 200 I6. and it does not take too much vac away. runs 16hg at idle with a pretty hot cam
Custom intake tube info (Cavalier, but good info for all) TheVis Engine 11 02-09-2007 04:44 AM
Building A 302 Chevy Scorpio Shaping Flow Hotrodding Basics 6 01-16-2007 05:55 AM
Beware of Weiand Action Plus intake! 454C10 Engine 3 03-11-2005 07:46 AM
Need some intake manifold help killerformula Engine 14 11-29-2003 10:07 PM
Intake Chevy Guy Engine 2 04-27-2003 08:06 PM
