2-bolt or 4-bolt - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-12-2002, 12:46 AM
New Member
Post
it should be fine. but if it is worrying you then buy a 4 bolt and say the extra money was for peace of mind. cheers!
it's all good as long it's not a Honda
  #17 (permalink)
Old 09-16-2002, 09:26 PM
Wink
my 2 cents
i have heard and read that 4 bolt mains were simply used to make up for a low nickel content in the blocks. if i recall a quote properly: "four bolts in mush are better than two".
vince
  #18 (permalink)
Old 09-17-2002, 10:50 AM
NAIRB's Avatar
Post
Since you already have a two bolt main block , just use it and don't worry, a stock 2 bolt main block will take more abuse than you would think. If you happen to have a four bolt main block, then use it, if you want. I wouldn't go out of my way to have a four bolt block unless, it was an extreme duty application, and in that case, I would have a two bolt block four bolted with splayed caps or use a bow-tie block anyway.
