2-bolt or 4-bolt - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2002, 04:16 AM
New Member
Question 2-bolt or 4-bolt
I am building a 355 chevy motor, and I am wondering if it will be really important for me to have a 4-bolt engine block, I have a 2-bolt block I sent out to be machined already, but it has been bothering me, wondering if it will stand long. But that doesn't worry me, because I'll easily be able to sell it again. But what I am wondering, is will the 2-block stand the abuse I will give it? I am building a primarily street motor, with a little drag strip use. Also the parts I am putting in it should end me out with ~400hp or so.
Thanks
Old 04-03-2002, 07:47 AM
Post
There are a great deal of 2 bolt chevys running on the strip without issues. I think with limited dragstrip use this setup will be more that adaquate. Under certain conditions a 4 bolt block is the best setup, you'll be fine for a long time.
For help in predicting the performance of you car and choosing gears, transmissions, tires ect. email me and I will run the specs of your car through PC HOTROD and email you the performance reports (See examples of PC HOTROD and the associated report at the following site:
<a href="http://pchotrod.com/Reports.htm" target="_blank">http://pchotrod.com/Reports.htm</a>
email address is as follows:
pchotrod@hotmail.com
Old 04-03-2002, 08:54 AM
1meancuda's Avatar
At a loss for words
Post
I agree with PC Hotrodder. For limitted strip use, a 2 bolt should hold up just fine. If you are seriously worried about it though, I would go ahead and get a 4 bolt. Built right, a 4 bolt would be ABSOLUTELY bulletproof!
Old 04-03-2002, 09:24 AM
New Member
Post
Thanks for the input, I have also read places about having the block splayed to a 4-bolt, but have also read about this causing odd stress on the block.
Any opinions on having this work done?
Thanks again for the replies, and all future replies.
Old 04-03-2002, 10:44 AM
Post
The splayed 4 bolt is superior to the regular 4 bolt main.
The 2 bolt main should be safe to 6500 RPM. If you are worried you might tax the 2 bolt main setup, then I suggest main studs, and not worrying about it any more. Noone I know has ever seen a main cap fail in a street type engine and you probably never will either.
4 bolt mains are highy oveerrated and probably 60% of the engines passed off as a "350 4 bolt" are really 2 bolt. There is no external way to tell you see, and many just add it on because it "sounds better". DOn't worry about your 2 bolt block!
Old 04-07-2002, 08:21 PM
chevyelc81's Avatar
Post
I have a 1981 camaro with a 350 2-bolt main. It has a forged crank, 9.7:1 forged pistons, and the edelbrock performer rpm package. I would estimate its pushing a little over 400 hp and I beat the crap out of this motor. I red line it at 7200 when I race someone or do burn outs. I drive it every day and and I race it on weekends. Ive been driving it for over a year now like that every day and I haven't had any problem yet. So from my personal experience with a 2 bolt block, im sure it will hold up easyly with your application.
Old 04-08-2002, 07:34 PM
igotachevyor2's Avatar
Last journal entry: couple of pics
Post
in every article i have seen it said that the 2 bolt block was good to 500 hp i have built several 2 bolts that were 350 to 450 hp with no problems
Old 04-09-2002, 04:16 AM
Post
My engine builder says the Chevy 2 bolts are actually stronger! If you go with the splayed bolts you'll be very happy. Chevy 4 bolts don't do much other than weaken the block itself with te straight bolts.
Old 04-09-2002, 07:58 AM
Post
Well, I think your engine builder is a little over zealous. The traditional 4 bolt block is not "weaker" than the 2 bolt arrangement, though the second bolts do come through a thin part of the web. The deal is that the 4 bolt arrangement allows greater clamping force with less torque on the bolts (check the specs!). Bolts can fail, main caps and webs almost never do. The 4 bolt arrangement also improves bearing saddle distortion.
However, the splayed arrangement is better because it does away with the thinning of the webs, and I think it may improve distortion of the bearing saddles over the traditional 4 bolt arrangement as well.
Old 04-09-2002, 04:13 PM
Post
Hi there;
About your 355 sbc.
If I was building the same and didn't expect to
rev over 6000rpm. I would use the two bolt block.
If the engine makes peak horsepower above that
and you will be revving above 600 by a considerable amount. then use a four bolt block.
I think that there are some who will dissagree
but that is what I would do.
Well that is my opinion. Good luck what ever
way you decide.
5.0killer
kenneth leger
Old 04-09-2002, 04:56 PM
Post
I have built a stroker 383 from a 4 bolt main block... why did I use the four bolt?...cause I didn't want to go through what you're going through.... worrying if I did it right!!!! Just get a four bolt and feel great when you hammer it!!!!
Old 04-09-2002, 05:05 PM
Post
I think that the 2 bolt main should be fine considering you don't over-rev. It should be fine considering that you are only shooting for 400 hp. Just make sure that the chassis mounting area is secure and not rusty or corroded. I've seen plenty of 500+ hp cars run 2 bolt mains all day long. I think that 4 bolt is way overkill.
pce out-
nitro guy
Old 04-09-2002, 08:09 PM
New Member
Post
As many racecars as i have seen and built, the 4-bolt blocks do better on roundtrack applications unless you are building an all out 500hp drag motor. Short answer....2-bolt is my choice when it is still streetable.
Old 04-09-2002, 09:09 PM
Post
depending on your final compression, your 2 bolt block will work. if you're gonna run this engine on the street and run pump fuel then you dont want to run more than 10:1 at which 2 bolts are more than sufficient. i say this because i have personally built race engines for Nascar Late Models at Rockford Speedway in Rockford,Ill. the engines that i built were 2 bolt blocks running 9.5:1 (limited by rules) turning 7500rpm and held up for several seasons without teardown or freshening.however the debate bout 2 vs 4 continues
Old 04-11-2002, 05:25 PM
New Member
Post
don't sweat it , unless you are going to run a blower ,or turbo ,or nitrous ,your 2 bolt will be just fine ..modest camshaft ,single 4 barrel750 cfm ,just drive it and enjoy it .......................don't forget to pressure-prelube the engine before you fire it ,make sure you have the good assy lube on lifters ,lobes ,rocker arms etc ..make sure you break cam in as the supplier reccommends ,usually 30 /45 minutes at 1800 rpm..should have a dandy engine ..set lifters/rockers engine off ,per MOTORS manual ,much less messy ..good luck ,let me know how it works out ..jim p...
