Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 2 bolt or 4 bolt mains. pontiac 455
Old 09-02-2010, 05:23 PM
WDCreech's Avatar
WDCreech WDCreech is offline
Grumpy Old Goat Herder
Eric is correct about the '58 to '62 forged rods (commonly known as rubber rods). In my opinion, cast rods are stronger. I used a set once and one broke at 5800 rpm, and of the rest, three were bent. As far as four bolt vs two bolt mains, unless you are going all-out racing, two bolt will be fine. It would be advantagous to switch to studs instead of bolts, though.
Bill
