2 bolt 400 or 4 bolt 350 chevy - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-29-2008, 10:40 PM
life is a temporary assignment
Don't go 60 over on a 400.....
  #17 (permalink)
Old 10-29-2008, 10:42 PM
stoneshrink's Avatar
Buickguy
Last journal entry: And now the new project
4 bolt v 2 bolt
With respect to SBC 400s, the 4 bolt main blocks are actually weaker then a 2bolt main.... also, forgot to mention that I'm using the production cast crank with my hp levels... for two reasons... I can build 3 400s for the price of a crank; and the car isn't a daily driver - so if it does go boom; it's more entertaining then aggreviating.
  #18 (permalink)
Old 10-29-2008, 11:34 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
I wish to disagree respectfully...
4-bolts are not weaker. The 2-bolt blocks have more meat in the main webbing, but the hierarchy of general "strength" goes like this: 2-bolt, 4-bolt, and the strongest is a 2-bolt block machined for 4-bolts. But to say that 4-bolt blocks are weaker is not the case.
  #19 (permalink)
Old 10-30-2008, 03:09 AM
3rdmember
i guess, BUT if you drive over your crank and crash, just exactly how much cheaper was it?
just a thought...
  #20 (permalink)
Old 10-30-2008, 08:42 AM
Buickguy
alien
But then the aliens will come down and keep me from crashing after I drive over my crank.
As for the weaker comment - I appreciate your viewpoint; but here is why I say that the 4 bolt main block is weaker. 1) the webbing on a 4 bolt main 400 is tapered where it connects to the sidewalls of the block - it is at that point that the other bolts connect to the main webbing... thus actually being less metal makes it weaker. 2) drilling more holes in a block does not make it stronger. 3) there is a 4 bolt that is stronger - that is where you buy aftermarket caps with splayed side bolts - which hold to the casing of the block. The problem with splayed caps is more financial then anything else as a DART block costs (without the inherent weakness) about the same as it does to buy the splayed caps and have them machined into the block.
But I understand that aliens are bringing a new block from Mars and that will fix all the other problems..... too much sarcasm? naw
buick 350 - chevy 350 72buick Engine 23 10-13-2009 08:38 PM
chevy 350 or pontiac 400 or 455??? MIKE T Engine 17 02-04-2007 07:34 AM
Pontiac 400 wider than Chevy 350 Goatman01 Engine 3 01-31-2007 12:11 PM
Buick 350 or Chevy 350 72Skylark Engine 21 02-02-2006 02:10 PM
Bolt pattern chevy 350 strokercuda Engine 2 12-02-2004 08:17 PM
