2 bolt intake - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2006, 07:05 PM
charley1's Avatar
hot rods forever
2 bolt intake
hi guys,
i have a two bolt pattern on my intake manifold, a 305 chevy sb.
when i replace the carb, will the carb with four holes match without leaking?
Old 02-01-2006, 04:12 PM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
Somehow, I think you lost me. Are you talking the bolts that hold the carb to the intake? I'm guessing that if that's the case, you have a 2bbl carb presently and are switching to a 4bbl carb. Once again, with the "if that's the case", you'll need to change the intakes unless you have an adapter plate (which I've only read about) to allow you to use a 4bbl on a 2bbl intake.
In a while, Chet.
Old 02-01-2006, 06:02 PM
boatbob2
2 bolt carb
hi ,if you go to speedway.com or jegs.com you can probably find an aluminum adapter for the 2 brl to 4 brl carb.ive never used one,so i cant tell you how much performance youll get out of it. but it should be better than the 2 brl.
Old 02-01-2006, 06:12 PM
steve t's Avatar
ex biker, now hotrodder
you need a 4 barrel duel plane intake, a adapter would be a waste of money, if you can even find one
Old 02-01-2006, 06:29 PM
jvsapp's Avatar
just a gearhead in paradise..
Last journal entry: last ones for now.
i've had a friend that tried to pinch some pennies when he changed his intake to a performer on his 350. he kept the 2 barrel carb(because he just changed it a month earlier) using an adapter, and the car was a total dog. when he finally changed to a holley 4 barrel, the difference was night and day. if you could get some pictures of what intake you have we might be able to help a little better. if you are planning to upgrade your 305 to a 4 barrel intake, you might be better off getting a rebuilt Q-Jet carb.
Old 02-02-2006, 08:03 AM
I think he's talking about the factory penny-pinching job where they bolt down a 2-bbl carb with only two bolts, diagonal from each other. He's wondering if a similar 2-bbl carb with 4 bolt holes will leak with only 2 bolts holding it. I figure it won't leak any more than the old one did, but I could be wrong.
Old 02-02-2006, 08:53 AM
I don't usually comment on engine stuff but I have run into this one. A 2 bbl that had the 2 bolt setup was changed out to a carb with 4 bolt holes and it worked fine. I have seen the carbs on these setups with 4 holes and some with just 2 but the number of holes in the carb does not seem to make much difference. Seems kind of cheap any way you look at it.
Old 02-02-2006, 10:40 PM
charley1's Avatar
hot rods forever
2 bolt intake
thanks guys,
for the information, i have a couple of intakes as options but looking which way would work. i think i can start to look at it more positively now. thanks.
charley1
Old 02-05-2006, 05:30 PM
charley1's Avatar
hot rods forever
2 bolt intake (picture)
here is the intake manifold. it needs to be cleaned up just pulled it off the motor a little while back.
Old 02-05-2006, 07:07 PM
302 Z28's Avatar
OK, I'll bite. Why are you calling it a 2 bolt intake?
Vince
Old 02-06-2006, 01:39 AM
Only 2 holes to bolt down the carb.
Old 02-06-2006, 06:17 AM
302 Z28's Avatar
Duh , never have I heard of one called that before.
Vince
Old 02-06-2006, 06:45 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
The other two holes can be easily drilled and tapped.
Old 02-06-2006, 04:52 PM
charley1's Avatar
hot rods forever
intake manifold
just a short description ,just unusual to find one with two bolts holding down the carb....
Old 02-06-2006, 05:24 PM
jvsapp's Avatar
interesting... what year was it from? my original 2 barrel carb intake has all 4 bolt holes. but it is a 77.
Offenhauser Dual Port intake? 454C10 Engine 21 05-10-2016 05:52 AM
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
351C intake manifold question....??? Steve-0321 Engine 3 04-25-2005 08:44 PM
Beware of Weiand Action Plus intake! 454C10 Engine 3 03-11-2005 08:46 AM
Removing fenders? Jag Daddy Body - Exterior 3 11-26-2003 05:42 AM
