Thread Tools Search this Thread share on Facebook
  #1
Old 02-23-2009, 02:02 PM
jgh64pkup's Avatar
jgh64pkup jgh64pkup is offline
Last journal entry: new et streets
2 bolt main to splayed
if i got 4 bolt splayed caps and put them on my two bolt main 350 and got it align bored would it make it stronger than a stock 4 bolt main
Register now (free) or login to remove ads
Old 02-23-2009, 03:04 PM
68NovaSS's Avatar
68NovaSS 68NovaSS is offline
Last journal entry: Fresh paint
Wiki Edits: 9
Yes, without a doubt.
''Life's tough, Pilgrim, and it's even tougher if you're stupid.''---John Wayne
Midnight Sun Street Rod Association
Old 02-23-2009, 03:08 PM
jgh64pkup's Avatar
how much would it cost i figured around 250
Old 02-23-2009, 03:12 PM
dawg's Avatar
dawg dawg is offline
NAVY VETERAN
Yes Much Stronger
Old 02-23-2009, 03:20 PM
68NovaSS's Avatar
Wiki Edits: 9
Um, splayed caps may require saddle machining and for sure machining of the caps themselves, the Milodon's I have required a .003 clearance on the outer flanges when seated in the saddles, and it will require line honing at a minimum, possibly line boring. the tab for mine, using my caps was about $800. Maybe blame the high cost on Alaskan prices, I don't know.
Old 02-23-2009, 06:17 PM
k-star k-star is offline
Last journal entry: PICTURE TEST
caps
I would doubt you could get the entire job done for $250.
Maybe if you put the caps on your self ,knowing what your doing you may get the line bore hone done for $300..
I charge $150 just to put the caps on.
I have to farm out the line bore/hone because i am not equipped to do it.
Keith
Old 02-23-2009, 08:26 PM
jgh64pkup's Avatar
its 225 to align hone it plus the price of the main caps
Old 02-24-2009, 05:17 AM
block
Are you going to install them your self??? If not i would assume that they will charge for installation. Also every conversion i have done needed line bored first, then honed. Does that 225 include the line bore also???
If so that is one cheep shop.
Keith
Old 02-24-2009, 08:20 AM
streetrodderbn's Avatar
streetrodderbn streetrodderbn is offline
Certifiable Streetrodder
remember, the splayed main caps only strengthen the main caps from walking/moving, there are many more variables that make a block "strong": amount of core shift, high nickel content, blueprinted:deck height, lifterbore, cylinder wall thickness and finish, ect...... All these factors can help the engine "strength"
Old 02-24-2009, 10:58 AM
jgh64pkup's Avatar
would it be worth the money to put the splayed main caps on and get all the machinig done or just buy an aftermarket block
Old 02-24-2009, 11:12 AM
heyjude076 heyjude076 is offline
Last journal entry: Bringing home the 401 Nailhead
Tell us the intended purpose of the engine. Street, race, etc. What vehicle? What transmission? Give these guys all the info and you will get more detailed advice.
Old 02-24-2009, 11:32 AM
CNC-Dude CNC-Dude is offline
A stock block can only withstand so much stress, with or without good caps. Whether they are splayed or stock cast 4 bolt caps. You just have to decide where you are going with your build, and what your true expectation is for its longevity. The weak link is the block, whether its a high nickel content one or not. A good aftermarket block is a pricey purchase, but might be more necessary for your application than trying to push a stock block too far....even with better caps!
Old 02-24-2009, 01:41 PM
jgh64pkup's Avatar
High performance street some track use its going in a 1964 chevy c10
i want a contender but dont want to go overboard
right now i have a 1971 350 i want to make it either a 383 or a 395 or if i go with an aftermarket block i would build a 406
want to make somewhere around 500 to 600 horse
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "2 bolt main to splayed"
ThreadThread StarterForumRepliesLast Post
Horsepower rating for sbc 4 bolt main block?beemdubyaEngine1510-29-2009 05:52 AM
400 Small Block w/4 bolt main ProjectAlexFLHS1188Introduce Yourself210-26-2008 06:39 PM
BBC 2 vs 4 bolt main capsclassic55Engine701-21-2008 04:44 PM
2 bolt mainnova33Engine111-08-2003 09:21 PM
diff in 2and 4 bolt main70 novaEngine102-16-2003 10:57 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
