2-Bolt rebuild question - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2010, 06:54 PM
Just starting a rebuild and am considered a beginner. I have a '79 350 2-bolt main block with casting number 3970010 and 010 at the timing cover. I am looking for a mild street/bracket build around 350-400hp and max 5500-6000rpm. My question is with the bottom rotating assembly.
I would like to reuse the stock crank once it all checks out at the machine shop and am wondering what to do with the main caps. Should or can I reuse the main caps or get 3 new centre ones or all 5. I will definatly be using ARP studs. The only caps I found are "angled" and I am pretty sure mine are straight. Does anyone have part numbers for me to look at or any other recommendations.
Thanks
Old 05-24-2010, 07:06 PM
2 bolt mains is plenty strong for that kind of power
Old 05-24-2010, 07:25 PM
GMC boogie's Avatar
I agree. Just go with what you have. I would not even spend the money on the studs.
Old 05-24-2010, 08:00 PM
Another question, since I have never taken a block to get machined, need a little advice as what to get done. Was going to get it decked (dont know how much or how to tell), bored 0.030 over (should clean it up) is getting the mains aligned honed worth it? Anything else I am missing.
So dont bother with the mains? Just reuse them?
Thanks again
Old 05-24-2010, 10:00 PM
#!new's Avatar
406C-10
if they are the same mian caps that came with that motor,then no you dont haft to get it aligned bored. besides when you do get one aligned bored the factory timing chain and rear seal may not work. in other words you would need a shorter timing chain and thicker seal. and a 2 bolt block will work fine for that build up although i would spend the extra money on the ARP studs, but to each his on.
Old 05-25-2010, 07:30 AM
Should I put a windage tray in this build? Not 100% what it does. Keep the oil from splashing and reducing drag while directing it better to the vitals???
Old 05-25-2010, 10:12 AM
my87Z's Avatar
Veteran/Firefighter-Paramedic
personally i would spent the money on the ARP fasteners, you will be just fine with a 2 bolt for what you are looking for and you would also do just fine with a stock style stamped steel pan
10 bolt rearend rebuild help Lil John Transmission - Rearend 6 03-27-2010 06:34 PM
My rebuild 12 bolt and new supension elcaminodragster Suspension - Brakes - Steering 7 11-05-2009 05:20 AM
Chevy 10 bolt front end question Magikal Transmission - Rearend 1 12-09-2007 01:00 PM
350 4 bolt question......... Trans Am Tony Engine 1 12-02-2007 08:31 AM
Bolt Strength Question jamnut Engine 16 03-30-2005 07:11 AM
