Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 2 compressors, which should i get?
  #16 (permalink)
Old 10-13-2005, 08:37 AM
toykilla toykilla is offline
Originally Posted by zimaad
Well, I don't think a compressor can really do "more" than you need!!! I just purchased the HF one recently. I'd have loved to get a 2-stage, but didn't have the $$$. The main way to get get a good 2-stage in your price range is to buy used. I know that Home Depot has a 2-stage for around $750-800 that flows a little more than the single stages we are talking about and at a higher PSI too. For about $800, you can get an IR single stage unit from Northern that flows about 17-18 CFM at 90psi. Online at Tractor Supply, it lists the same thing for slightly cheaper but with an 80gal tank instead of the 60 at northern. The 2-stage version is a few hundred more at a little over $1k. You can also keep an eye out in papers for local auctions/body shops closing down. I saw two 120gal 25+CFM models (one IR and one Snap-On) go for about $1000 each when a local body shop was closing down. It would have been great to get one...just out of my budget for now. I've also seen some good compressors go on ebay for good deals. of luck. So far, I've been happy with my HF single stage unit. I haven't use a DA sander yet, but I figure this unit will be ok for me for a number of years.
What all have you used the HF compressor for? I will be using a DA sander, but not very often.
These IR compressors are single stage, but flow alot more air then the HF and Craftsman units. They are more expensive than i want, but if there is no other way, then i will have to bite the bullet and get one.
$799 with FREE shipping:
