Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 2 compressors, which should i get?
  #25 (permalink)
Old 10-31-2005, 06:41 AM
oldred oldred is offline
x711, From your discription it sounds like you have your dryer mounted on the tank? If so it will not do much good in that location and really should be located well downstream from the compressor itself or at least run the air through a cooler between the tank and dryer. There was a discussion here about water in the air lines just in the last few days.
