Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 2 compressors, which should i get?
  #30 (permalink)
Old 10-31-2005, 08:17 PM
x711 x711 is offline
re:compressors, which should i get?
OldRed, I did my research in advance and have seen many air layout diagrams.
With my setup "Home Garrage" the actual run to my gun is minimal so I dont
see any problems with what I have now. If I had more space and the budjet
I would put in a chiller or move the water trap/dryer further down the line
away from the tank as an experiment to see if anything could be gained.
Currently though I see little advantage to this as I am not running into
any problems laying down paint or primer.
But if I can draw on your experience, what would be the advantage of
re-doing what I have. Any advice is most welcome.
Also I am curious are you in a body shop or have you got a home setup.
What type of compressor / dryer system / gun etc do you use.
Is your measured air temperature at the end of the line cooler /warmer
than the area you paint in.
Thanks in advance. X
