2 Different heads on same motor?
I just received my 350 engine today and noticed that they have two differnt head casting numbers on it.
14096219 and 14102191 I did a little research and found out the 219 head has 1.94/1.50 64 cc and found conflicting info on the 191 heads, I found one place saying 1.84/1.50 76cc heads and other saying 1.94/1.50 64cc heads, please help this is a 350ci 88 motor and will be going into a boat.. MAYBE... can I run both of these heads with no problem? |
I agree, I ordered this engine so I feel I shouldnt have to pay any more money to have this probem fixed, I will contact the vendor and have them correct the problem, but if they are the same match as far as CC and valve size gos, but just with different casting numbers, I dont want to go thru the trouble of taking the heads off and sending them back to the vendor since they already came instaled on the engine.. |
This is fairly common with high volume rebuilders. As long as the chambers are the same CC and the valve size is the same most people will never know, Doesn't mean that it is right. Truth is on a stock rebuild most folks would never know if one head has 1.72's and the other has 1.94's. When a dollar bill gets involved there's damn few people I trust anymore.
I made a mistake on the casting numbers... its a 7 not a 9, not 14096219 should be 14096217 casting and the other is correct 14102191, so I have casting number 14096217 and 14102191, as far as I can tell they have the same CC and valve sizes unless anyone knows different I am going to run it the way it is.....thanks for the comments
boat engines are under heavy load compared to car engines. I would use nothing other than a premium engine in a boat.Cars are easier to get a tow truck when they break down.Its a long walk from the middle of a big lake
Do a google search and you will find the difference between those two different heads.
One is a L-98 replacement {replaces the "083" TPI head) (also used on the older 350-285HP and 350-300HP crate motors, and marine 350's). The other is a swirl port head. For a TBI truck 350. Call the builder. The right head for your marine motor is the 217 head. The swirl port head has a swirl vane in the intake port and a bump right at the pushrod pinch instead of a radius shaped port wall. Induces swirl and turbulence for Low rpm truck motors. Each has its purpose but they are not the same. |
but after pulling many chevy sb's out of boats and open'n them up.. there is nothing remotely special about them.. unless you call cast cranks, cast pistons, special.. |
um im familiar with mercruiser marine engines. they use different material for the crank shaft than automotive engines. that is a fact. also tha camshafts are CLOSE to stock truck cams. again im familiar with mercruiser engines. the blocks are also using materials that are more resistant to corrosion. .maybe you can put a automotive engine from a car and have it run in your boat if you know its quirks, but marine does use premium stuff to some degree. maybe not for performance but there is a degree of premium there.
same cast crank(same casting # as my 350 car crank), same rods, same cast or in later years hyper pistons same heads, I'd have to look but I think the 96 we just replaced in my dads boat was 2 bolt mains.. other than the fuel system having 2 fuel pumps, the tbi was standard affair.. the distributor cap was different and the reluctor wheel.. exhaust manifolds, standard sbc stuff.. oh, no air cleaner, just an alum fire stop. |
| Come on motor heads | oldsmo | Engine | 12 | 03-24-2006 08:07 PM |
| Which heads for my Motor? | Jimmy Neutron | Engine | 7 | 11-09-2005 10:30 AM |
| bored motor heads | Needaknowwhatiam | Engine | 1 | 10-29-2003 05:06 PM |
| Windsor Sr. Heads Too much for my motor? | Red70Mustang | Engine | 3 | 05-20-2003 10:40 AM |
