Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 2 Gas related Questions
Old 11-30-2006, 03:38 PM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
Hotrodders.com moderator
Wiki Edits: 3
Now I would suggst that you rig up a gallon can from to pull fresh fuel from..disconnect the fuel line from the tank and run it to the gallon can...works just fine for gettin one of those running in the first place..
The old gas can be taken to one of the Hazmat disopsal sites..Should be one around there somewhere..
Then clean out the tank as I have found ther is rust an water in those and tha treally meeses up a carb..Good fuel fileter is mandatory so put one of those somewhere..
Sam
