Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 2 Gas related Questions
Old 11-30-2006, 09:55 PM
MI2600's Avatar
MI2600 MI2600 is offline
Member# 3287
There's a check valve/needle under the shooter. That may be stuck. But, as stated above, the engine should still idle/run.
Some spray carb cleaner and a good blow out will probably solve your problem.
