Originally Posted by johnsongrass1
Try filling the carb bowls with fuel instead of blowing up your self with starter fluid in a can. Squeeze in about 100cc of fluid and pump the throttle once or twice till it shoots fuel out of the shooters. Start vehicle.
Ya, to fill the bowls, just use one of those mustard squeeze bottles with a nozzle and stick it into the vent tubes.
I'd drain all that old gas out of the tank and flush the tank and lines with thinner.
I have seen a hole punched into the lower corner of the tank with an ice pick to let the fuel/ thinner drain out, and then a screw coated with tank epoxy to seal the hole. Red-neck, but it works.
