2 part ?/388 stroker
! anyone using VTO orange valve seals have trouble w/ them splitting "vertically" ? I have had to replace 9 in 8000 miles, heads were[new at the time] brodix ik200. Guides feel tight
2 Fired up the engine to warm it up to change oil,usually I do this after a ride but didn't have time, cranked up the idle to 1500 ,by the time I had operating temp [180] the first foot of the headers was glowing dull red. So ,too much fuel? not enough timing, product of cam overlap? never noticed this before , just curious, cam is FT hyd. 232/234@ .050 -.490 lift . Initial timing -14* 34 total all in by 2000, no vac adv. dave |
383 problems
1. Have you checked valve retainer-valve seal clearance at full lift?
2. Every engine I've had on the dyno showed high EGT's at fast idle with no load on the engine. I think whats happening is; A) the timing isn't at full advance, B) the carb is almost closed and not flowing enough air to make the boosters flow fuel and you have a lean condition. Both these conditions will cause high EGT's. By the way when you load the engine and open the throttle to maintain rpm the EGT's will come way down. Next time try this: start the engine and crank the timing up to 50*. The headers should run cooler. They may still glow but not as bad. Don't run the engine at that timing. Crank it back to 34-38*. Ron |
If I were to run initial timing that high, I wouldn't be able to get the idle down to a reasonable level, carbs are almost closed at 1000 rpm, lobe center is 108 . thanks for reply's. Valve retainer clearance is Over .100 [quick measurement]
dave |
well the lack of idle spark advance really make the exhaust run hot.
The fuel burns in the exhaust instead of in the combustion chamber when the timing is not high enough at idle. Take the carbs off and reset the secondary throttles opening. They may be open too far at idle. |
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Midnight Sun Street Rod Association |
FT=FLAT TAPPET . Secondaries adjusted down to just where they won't stick closed ,pri. are maybe 1/2 turn open [idle speed screw] idle emulsion screws out about 3/4 turn , runs excellent, was just curious about " real hot pipes" .
dave |
| Can you I.D. this part? | speedydeedy | Hotrodders' Lounge | 5 | 01-22-2011 11:44 PM |
| chevy 383 stroker starts but wont stay running the specks for the most part are here | pealjoints | Engine | 3 | 08-06-2009 05:26 PM |
| Name this part | Kevin45 | Hotrodders' Lounge | 10 | 01-12-2004 09:15 AM |
| i need some part id help | Lightspeed | Hotrodders' Lounge | 6 | 10-14-2002 07:52 PM |
| looking for part | SPIKEMAN | Body - Exterior | 1 | 05-13-2002 10:47 PM |
