Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 2 part Motorcycle tank. Need technical spraying advice Want DEEP Gloss Without runnin
Old 11-01-2005, 11:03 AM
Red5's Avatar
Red5 Red5 is offline
New Member
That has a VERY nice shine.
OK, So what do these directions mean:
1 Apply 2-3 medium wet coats plus a drop coat.
What is a wet coat and what is a drop coat?
Allow 5 minutes flash time between coats.\\\
Now on the clear coat directions it says:
Apply 2 medium wet cross coats.
What are wet cross coats?
Allow to flash handslick between coats. A Wet on Wet Limited Flash application can be used, allow 2-5 minute flash between coats.
Can you help me make sense of this?
