2-piece Alloy Wheel Restoration Help - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-06-2007, 08:40 AM
I have these "new old school" wheels that I love very much and I'm looking for recommendations on removing corrosion inside the wheel barrow and polishing the lip.
Old 10-06-2007, 06:37 PM
30desoto's Avatar
Dodge ain't all bad
Shin
I see you have no response yet so will give my 2 cents worth.
I would disassemble them and duck tape the area you want to polish.
Then if you have a glass bead system I would gently glass bead the rust area.
If no glass bead system then I would wire brush with a drill on the rusted area.
Then you would sand with about 320 and use wax and grease remover on them.
Then I would spray will a couple coats of clear to seal them.
Then you can polish the chrome and if you want sand and repaint the centers.
30dee (now you might get more responses)
Old 10-08-2007, 04:04 PM
Actually, the barrels are aluminum. I guess it's just corrosion and brake dust that make'em seem rusty.
Old 10-08-2007, 04:47 PM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Do not take a die grinder to them. If they are aluminum you can polish them. It will take some time though. And what are you going to do with the spoke section? Polish, paint, powdercoat? You can actually sand the aluminum section and if you have a buffer of a lot of elbow grease you can go at it that way. You can get some buffing kits / compounds from Eastwood, or places like J&L Industries, MSC, etc. You can start out wet sanding with 600-1000 grit and then start polishing. To polish/buff would be best done with a pedestal style buffer, but it is possible to do it with different types of equipment with felt bobs and felt/wool wheels and varying compounds, starting with a midly agressive grade and working your way up to a fine grade for a high polish.
Kevin
Old 10-10-2007, 03:01 PM
Sounds like a plan. Looks like this weekend is set aside for these wheels.
P.S..
I will powder coat them and update this thread as the restoration progresses.
Old 10-10-2007, 09:30 PM
Those are "Mini-lites" aren't they? I love the looks of those wheels, very cool.
Old 10-11-2007, 05:46 PM
The do look like Mini Lites, but they're RS Watanabe RS-8. They're for my daily driver, 89' 240sx.
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 09:45 AM
Ford Steel Wheel Tech wheelkid General Rodding Tech 9 01-07-2007 06:31 PM
Spindle interchanges bskaggs Suspension - Brakes - Steering 11 06-05-2006 01:29 PM
Steering wheel decision help guba_unus Suspension - Brakes - Steering 2 02-12-2006 10:21 AM
Steering Wheel replacement tbag231 Introduce Yourself 1 10-10-2004 10:56 PM
