2 problems distributor, spark plugs?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2008, 10:52 AM
car 74 pontiac 455 eng. (drive once or twice a month) problem: car starts, revs up, then dies. try to re-start, it floods, have to wait an hour then it runs fine as long as I rev it high for about a minute. Now it will not start. (eng just turns) popped the MSI distributer cap and saw a pale green color on the points. (no buid up on contacts or ignition rotor ) but looking further down, I could see there was a lot of rust above the distr. gear. next...checked a couple of plugs for carbon build up. looked fine, however, plug wire won't stay connected to spark plug now. push it in and it keeps falling off. I never messed with any of this before so suggestions are greatly appreciated.
Old 07-27-2008, 11:04 AM
T-bucket23's Avatar
Wiki Edits: 26
Sounds more like a choke or fuel issue to be honest. If the choke is not opening a little when it first starts, it will flood and die quickly. Sitting for a while will ry the gas out and it will restart. If this has the original carb setup there should be a vacuum operated choke pull off on the right side of the carb. When the engine is cold the choke should close, as soon as it starts the vacuum pull off shold open the choke about 3/16 or so.
Chet
Old 07-27-2008, 11:54 AM
Pictures of Engine
Here are some pictures of the engine
ID:	31476   Click image for larger version
ID:	31477   Click image for larger version
ID:	31478   Click image for larger version
ID:	31479   Click image for larger version
Old 07-27-2008, 12:00 PM
Is this in a boat? I haven't seen so much corrosion in a distributor, perhaps ever. Just throw this baby away and get a new one, the cost and time to fix this will be more than replacing it. Then drive it more often and try to park it some where dryer.
Bogie
Old 07-27-2008, 12:32 PM
Your right! seems to be a fuel issue. fuel pump turns over but very little gas entering carb. how do I fix this myself? MSD racing fuel pump/filter (life time warranty). rebuilt last year by MSD .Could just send it back but takes about a month/ (fyi.. no choke). it's been locked open (I guess for racing). It has the shaker hood which is notorious for allowing water on the engine. Car cover causes more problems with the 100 %humidity and temps in Fla.
Old 07-27-2008, 12:37 PM
as far as spark plug... crimped the wire with pliers where it connects to plug. stays on now
Edelbrock heads / spark plugs ? driveability Engine 8 03-13-2006 07:29 PM
SBC Still fuel fouling plugs, Losing my mind! 67 Deuce 4 Me Engine 9 09-02-2005 08:56 PM
plug fouling and other tuning problems slow ride Engine 3 08-04-2005 07:35 PM
what spark plugs are best? 72 chevy elcamino Engine 4 07-12-2005 08:59 PM
UR5GP G-POWER Plugs in 351 Windsor ve3ham Engine 0 04-22-2005 10:40 PM
