Thread Tools Search this Thread share on Facebook
  #1
Old 07-12-2004, 01:20 PM
dbuff's Avatar
dbuff dbuff is offline
Radiator flush - KOOL CLEAN , CLR which best?
Hello.
Needing to attend to alot of debris in radiator on 67 cutlass w/330 and car has put up for a LONG time.
Was reading old message from Chuck about Kool Clean. Here info on that - quotes here -
" Basically similar to the product "CLR" without the soap so there is little foaming. Works like a charm and cleans head coolant cavities so clean you would think they were fresh cast.
Not cheap though. "
juveteach says :
"FOUND IT !!!!
You will have to call a company called THE CARE EXPRESS
@ 800-339-3880 and ask for item number # 25133, KOOL KLEAN.
It only comes in the gallon or a case.
Its about 30+ and the S/H. "
Any suggestion on best procedure for flush ? What ratio of KOOL CLEAN to use when flush? This radiator is really ruff,are there any pitfalls to avoid when flushing?
As always, Thanks.....
Register now (free) or login to remove ads
Back to top
Search this Thread:
Advanced Search
vB code is On
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
