2 Questions: Transmission? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-16-2009, 11:52 AM
I am hooking up my electric speedo, with the sensor cable adaptor, I have an adaptor between my cable and trans I am going to use to mate each other. I have a hard plastic stem that seems to go in there approx 2 inches long so the speedo can read, is this correct? Seems way to loose for me! Next que: I do have a fluid leak around my flywheel cover (bolts) and before I start tearing apart any quick suggestions on what I should look for or check-out first? Thanks, Dana Gasket seems fine but my trans pan seems pretty wet also!
Old 08-16-2009, 12:42 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
What transmission are you working on? Maybe I missed that
Old 08-16-2009, 01:24 PM
350 transmission,
Doug Nash 2spd auxliary transmission questions slide Transmission - Rearend 3 07-20-2009 03:08 PM
I'm the new guy with a lotta questions. Can you answer all of 'em? LittlePwny Engine 17 04-10-2009 02:08 AM
Possible TH350 transmission breakdown? mars77 Transmission - Rearend 2 04-26-2008 04:26 PM
1991 Chevrolet K2500 4X4 transmission problems Craig Eppley Transmission - Rearend 15 02-25-2008 05:02 PM
'80 Regal Transmission swap Nalehed Transmission - Rearend 3 06-07-2007 06:58 PM
