Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 2 sbc questions
Thread: 2 sbc questions
  #22 (permalink)
Old 01-27-2013, 11:36 PM
techinspector1's Avatar
techinspector1 techinspector1 is online now
Wiki Edits: 326
Originally Posted by jo5hi3 View Post
will a 2 bolt main be able to handle a 425 hp 383 stroker?
Yes.
also would a pair of double hump heads work well with the stroker?
They should make good torque in the lower rpm range, up to the torque peak anyway. This is not necessarily a bad thing if you are wanting a good stout street motor. At some point in the upper range of rpm's, the intake ports will stall and the motor will nose over. Most of those double hump heads are around 165cc's intake runner volume, while you need somewhere around 200cc or a little larger runners to support a 383 to 6000. If you're going to limit revs to under 5000, then the humps will work fine. It won't be a race motor, but it will make good low end torque to pull a heavy car around town.
