Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 2 sbc questions
Thread: 2 sbc questions
Old 12-14-2003, 09:31 PM
Robinson Robin Robinson Robin is offline
Ya its usually better to air on the side of caution with compression ratio's especially if you havent had a whole lot of experience. Most the guys that manage to run high static comp ratio's on the street have though out the combo very carfully and often had to do some trial and error. There isn't a whole lot of power to be gained from for example going from running high compression ratio's either although it does help restore some of the power at low rpms when running a cam with alot of duration
