rifraf, I can't even make sense out of your posts. If you know so much, why are you asking these questions?
You guys are on the verge of being trolled. Troy |
The stock parts should be fine on the 425 HP range engine. I would also not just toss the double hump heads. They make great torque and are killer street heads. I have a set that are pocket ported and gasket matched on my 400 SBC. I run a pretty fat cam to help make up for the flow on the heads, and it is a very respectable engine. I have never dynoed it, but I would put it in the 375 HP range or maybe a little more. Chris |
With these parts you can make that kind of power, but
the camshaft to make it all happen would not be a good streetable piece. I would suggest getting a set of 200 cc heads with 2.05" valves. These heads are large enough and flow enough air at low lift to use a mild camshaft. This would get you to your goal much more cost effective. Cstraub |
yeah forgive me if you thought I was knocking hump heads, but I think you're making the same point I was. I don't think you're going to be in the 400 horse range with them, that's all I meant.
K |
yeah the intake runners on the camel humps heads just arent big enough to support a stroker but they do make a really good street head
Yes.
They should make good torque in the lower rpm range, up to the torque peak anyway. This is not necessarily a bad thing if you are wanting a good stout street motor. At some point in the upper range of rpm's, the intake ports will stall and the motor will nose over. Most of those double hump heads are around 165cc's intake runner volume, while you need somewhere around 200cc or a little larger runners to support a 383 to 6000. If you're going to limit revs to under 5000, then the humps will work fine. It won't be a race motor, but it will make good low end torque to pull a heavy car around town. |
Snookered again.....
Not all posts to old threads are a bad thing, but in this case it's a waste of time and space IMHO.
There used to be a line of red font text that popped up if someone were to try to post to an old thread. Can it be reinstated? |
