2 Simplicity mower deck follower arms as panhard? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-16-2011, 02:57 PM
Wiki Edits: 31
I have a Simplicity/ Deutz tractor that I'm parting out. bought it to get running, but it's too far gone.. pulling the deck off the other day, and noticed the follower arms have a bolt/ sleeve on 1 side, but are thredded on the other side for a 1/2" rod end.. Thinking I could cut the bolt/ sleeve sides off and weld the threadded ends togther and then weld another sleeve overtop for extra strength. assembled length would be about 2'.. any reason this would not work?
Old 11-19-2011, 08:36 AM
streetbruiser's Avatar
if you can think it you can build it
panhard bar. elcaminoman69 Suspension - Brakes - Steering 10 11-24-2013 08:26 AM
4 bar & panhard blackbart Suspension - Brakes - Steering 41 11-24-2009 08:33 PM
Panhard question... low budget rodder Transmission - Rearend 0 07-24-2009 11:59 AM
The simplicity of rodding? Nightfire Hotrodders' Lounge 20 02-07-2006 09:46 AM
O2 fuel injection and simplicity NXS Engine 15 05-24-2005 01:33 PM
