2 speed cooling fan - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-30-2009, 10:50 PM
71corvette's Avatar
2 speed cooling fan
I just bought a Walker CCI-1770 fan/shroud combination. the fan has 3 wires and they say to connect the two positive wires together the brown one and the grey one, then black to ground. run power thru a 70 amp relay. my question is can I run just one hot leg for low speed and then connect the other hot leg when high is needed? both together produce high speed and either grey or brown individualy produce low speed.
Old 10-01-2009, 07:43 AM
302 Z28's Avatar
You most certainly can, but it will require a relay for low and another for high.
Vince
Old 10-01-2009, 01:46 PM
My question would be "why"? The whole point of an electric fan is to be able to turn it off when you don't need it. Why aren't the two speeds simply "off" and "on"?
Old 10-01-2009, 01:56 PM
71corvette's Avatar
Because of the noise fans
make on high. I have a 4 core aluminum radiator and with the 5.3 low speed will handle it 90 percent of the time
Old 10-01-2009, 10:40 PM
life is a temporary assignment
Mine stays on high, And the only time it goes off is when the key is off.
Old 10-01-2009, 11:22 PM
71corvette's Avatar
that would not work on my fuel injected 5.3. it would never reach operating temps for the computer to work properly. they like to run in the 200-220 degree range. I have seen many very nice cars drive up and the first thing you hear is the electric fan running. maybe I am just wierd but i dont want to hear the fan running, I would rather listen to it lope with the big cam.
Old 10-01-2009, 11:46 PM
Never had that problem with any of my cars..
Old 10-05-2009, 04:38 PM
daoldbuick's Avatar
same situation
I got the same situation as you 71corvette, and I don't understand how to wire it to a temp sensor to get the fan to come at low and then later on high as the temp dictated. Do you need 2 temp sensors? Temp sensors, from what I can figure out, are just variable resistore. They don't seem to come in varing temp settings like a thermostat. So how do you wire it so the 2 speeds will come on at different temps? Can it be done with one sensor?
Old 10-07-2009, 06:13 AM
71corvette's Avatar
you will need 2 two temp sensors or an electronic controller, hey make temp sensors that have a turn on and turn off temp. I am using my factory engine control computer, it has high and low speed controls built in. two temp sensors would be easy to do also. try summit or jegs for the sensors
Old 10-07-2009, 08:44 AM
Why not call Walker at 1-800-821-1970 and ask them about connecting the motor leads for high and low operation.
Old 10-07-2009, 11:45 AM
SSedan64's Avatar
Variable Speed Control
This is what I use, works very good. More Info in the Pdf.
http://www.flex-a-lite.com/auto/html...cessories.html
http://www.flex-a-lite.com/auto/31165-99943.pdf
Got it cheap on Evilbay.
Old 10-07-2009, 08:06 PM
71corvette's Avatar
thanks for the number, nothing came with the fan except to say use a 70 amp relay
New fan with adjustable temp control help redride Electrical 3 05-30-2009 11:22 AM
95 Mustang 2 speed electric fan & 351? macx Engine 3 09-01-2007 02:13 PM
Help! Electric Cooling fan set up. How do you... camaro freak Engine 4 08-19-2007 09:29 PM
Cooling Fan (push or pull)? Slant3 Engine 3 07-01-2005 08:39 PM
cooling fan problem Johnny Bravo Electrical 1 07-11-2003 04:12 AM
