Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 2 speed power glide
Old 07-14-2003, 07:41 AM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Wiki Edits: 21
Yes, the CI unit has a rear pump so can be push started. In fact, my wife's '56 Bel Air hard top all of a sudden qiuit shifting into second. Turned out that the rear pump ring had split and was dumping front pump pressure.
