2 speed power glide - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2003, 03:56 AM
APACHEMAN's Avatar
2 speed power glide
A friend is giving me a 235 from an Impala that runs great. I don't know what year the Impala is. I'll find that out tomorrow. If its a '62 or older I'm told I have to get an adaptor ($350) to use the th350 I have. If this is the case I may use the 2 speed powerglide instead. What are the pros and cons of this trany?
Old 07-11-2003, 07:50 AM
willys36@aol.com's Avatar
Wiki Edits: 21
I'm not sure about the timing of the switch to the 'late model' Power Glide but if your tranny is attached to a 235, it is likely the less desireable early vesion. If it is the cast iron version, forget it. '63 sticks in my mind for the date of the conversion to mate up to the new 215/230/250 series of straight 6s. The '63-up version is a very good tranny and still has a slew of upgrade parts available. Still in demand by drag racers. I think you are stuck getting the adaptor reguardless of which tranny you run.
Build the 235. Great engine and can be made into a perky performer that isn't a belly-button SBC. I just rebuilt mine for my '53 Chevy pick up with all the hot mods (milled the head 0.100" for 9:1 compression, 280 cam, electronic ignition, Clifford 4-bbl intake, Fenton cast iron headers, full flow oil filter). I got the adaptor for the late model tranny and am using a 2004R OD. I used a Power Glide behind the 230cu in 6 in my son's '36 Pontiac (pictures in my photo album.).
Got my adaptor from Stovebolt Engines
http://www.stoveboltengineco.com/index1.htm
Got my intake from Cliffords
http://www.cliffordperformance.com/home.htm
Old 07-14-2003, 03:37 AM
If I remember correctly, a cast-iron PG can be push-started.
Old 07-14-2003, 07:41 AM
Wiki Edits: 21
Yes, the CI unit has a rear pump so can be push started. In fact, my wife's '56 Bel Air hard top all of a sudden qiuit shifting into second. Turned out that the rear pump ring had split and was dumping front pump pressure.
