2 speed power glide bolt on? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2011, 10:05 PM
i have a 1965 chevelle "in progress" it has the stock 2 speed power glide with 97k actual miles still runs and drives, but needs a lot of tlc, it is 100 percent all there, chrome, lights, on its 2nd set of tires but it is for sure worth the restore,my question is it has a streight 6 not sure of cubes but i am pulling it rebuilding it and putting it on a stand in my garage,i am putting a L t 1 350 with a few modifications,IE cam heads etc...but i would like to know if the original 2sp.pg. will bolt up to and handle the l t 1 can someone help with this question thanks
Old 07-28-2011, 05:24 AM
SSedan64's Avatar
It will bolt up fine, will need a good rebuild & possibly a few parts changed to be reliable.
Old 07-28-2011, 06:30 AM
Will I ever get it done?
Last journal entry: Hood
The 65 will have a rear pump. You would probably want to find a 67 or newer glide, preferably from behind a V8.
Old 07-28-2011, 11:13 PM
2 sp.pg. or 350 turbo
I have both 2sp.pg.and a 350 turbo on hand on hand what would you guys think best?
Old 07-29-2011, 12:59 AM
Why do you recommend the t h overthe 2 speed powerglide?
Old 07-29-2011, 06:06 AM
IMHO, powerglides serve two purposes. First, they were relatively inexpensive and simple (GM wanted to make a profit back then) and they were durable. Second, in light weight drag cars that don't need multiple gears, they provided a platform that was relatively inexpensive and simple and durable.
For the street in a relatively heavy car (compared to a 2000 lb. drag car) that experiences different terrains and speeds (opposed to a 1/4 mile full throttle burst), the more gears the better.
Old 07-29-2011, 03:23 PM
SSedan64's Avatar
X2^^ use the TH350.
Old 07-29-2011, 03:59 PM
ok,one more question,use the lt1 or the beefy 454 i have
and would the 454 bolt onto the 2sp.pg or the 350th
Old 07-29-2011, 04:50 PM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
I gotta say 454.
Both trannys would bolt up to it although you may want to consider a TH400 if you use the 454.
To Power Glide, Or not to Power Glide 68Elcamino Transmission - Rearend 3 06-25-2010 05:59 AM
350 Power glide chappell Transmission - Rearend 4 03-21-2008 10:47 AM
Power Glide jmbjs Transmission - Rearend 7 04-21-2007 01:30 AM
power glide? nitro_baller4692 Transmission - Rearend 1 09-24-2006 04:19 PM
2 speed power glide APACHEMAN Transmission - Rearend 3 07-14-2003 07:41 AM
