-   -   2 wire retractable antenna (http://www.hotrodders.com/forum/2-wire-retractable-antenna-221240.html)
BrowniesMerc 07-02-2012 06:56 PM
Hi guys
I have a 2 wire retractable antenna, beleive it is a ford but not sure. To extend, one wire hooked to positive, the other negative, and reverse these two to retract. I need to find a switch to put into my console that reverses polarity to control this ( apower window switch, etc is what I am thinking to match my interior)
Any ideas?
Thanks in advance
EOD Guy 07-02-2012 08:50 PM
search for a spring loaded SPDT switch
DPDT Center Off Spring Loaded Switch
EOD Guy 07-02-2012 08:52 PM
search for a spring loaded SPDT switch on ebay
2 TOGGLE SW SPDT ON-OFF-ON SWITCH MOMENTARY 15 AMP 15A | eBay
vicrod 07-02-2012 08:56 PM
1 Attachment(s)
See attached wiring diagram.
vicrod
ogre 07-03-2012 02:00 PM
like vicrod posted, you need a dpdt - double pole, double throw switch with a spring centered
or just buy a power window switch
EOD Guy 07-03-2012 05:37 PM
1 Attachment(s)
Or you can use a SPDT switch and a couple of bosch relays
evolvo 07-04-2012 06:51 PM
Shouldn't an electric antenna work with the radio on/off knob? You know, turn the radio on and antenna extends, turn radio off and antenna retracts. It should also retract when ignition key is turned off, IIRC.
BrowniesMerc 07-13-2012 06:16 PM
thanks
Thanks Guys
Got it all figured out now
Chris
EOD Guy 07-13-2012 08:42 PM
How you end up doing it?
BrowniesMerc 07-15-2012 08:07 PM
re 2 wire antenna
I ended up using a dpdt switch 6 pin to reverse polarity
