2 wire retractable antenna - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2012, 05:56 PM
Hi guys
I have a 2 wire retractable antenna, beleive it is a ford but not sure. To extend, one wire hooked to positive, the other negative, and reverse these two to retract. I need to find a switch to put into my console that reverses polarity to control this ( apower window switch, etc is what I am thinking to match my interior)
Any ideas?
Thanks in advance
Old 07-02-2012, 07:50 PM
EOD Guy's Avatar
search for a spring loaded SPDT switch
DPDT Center Off Spring Loaded Switch
Old 07-02-2012, 07:52 PM
EOD Guy's Avatar
search for a spring loaded SPDT switch on ebay
2 TOGGLE SW SPDT ON-OFF-ON SWITCH MOMENTARY 15 AMP 15A | eBay
Old 07-02-2012, 07:56 PM
vicrod's Avatar
life is a ride
Last journal entry: LED tail lights
See attached wiring diagram.
vicrod
File Type: pdf forward reverse DC motor DPDT switch.pdf (196.2 KB, 23 views)
Old 07-03-2012, 01:00 PM
ogre's Avatar
the 'Duracell Project'
like vicrod posted, you need a dpdt - double pole, double throw switch with a spring centered
or just buy a power window switch
Old 07-03-2012, 04:37 PM
EOD Guy's Avatar
Or you can use a SPDT switch and a couple of bosch relays
Name:	pwr antenna wire dia.jpg
Old 07-04-2012, 05:51 PM
evolvo's Avatar
Heathen
Shouldn't an electric antenna work with the radio on/off knob? You know, turn the radio on and antenna extends, turn radio off and antenna retracts. It should also retract when ignition key is turned off, IIRC.
Old 07-13-2012, 05:16 PM
thanks
Thanks Guys
Got it all figured out now
Chris
Old 07-13-2012, 07:42 PM
EOD Guy's Avatar
How you end up doing it?
Old 07-15-2012, 07:07 PM
re 2 wire antenna
I ended up using a dpdt switch 6 pin to reverse polarity
antenna, retractable, switch polarity
FORD Retractable Hardtop 57 58 59 4speed Hotrodders' Lounge 16 08-21-2011 08:52 AM
Need Some Fabrication Ideas - Solutions for a Retractable Panel icsmannn Body - Exterior 3 05-21-2010 08:14 PM
retractable radio antenna wstory Electrical 4 07-08-2008 11:41 AM
Wiring Questions Retractable Licence Plate Ratchet Electrical 8 12-22-2005 12:38 PM
retractable hardtop rlackey Body - Exterior 2 02-18-2005 03:22 AM
