2 x single MC or 1 x dual MC? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2006, 02:11 AM
staleg's Avatar
Last journal entry: Hand brake
To avoid the use of power booster but still don't have to push the brake pedal very hard, I've been told I can use two single master cylinders (one for front brakes and one for rear brakes) together with a 6,25 to 1 ratio on the pedal.
The point with the twin MC is to move lots of fluid= less pedal travel.
Wilwood have setups like that.
Would you say this is a race-only setup, or is it suitable on a rod too?
The car is a 34 Ford with 4x disc.
Old 07-12-2006, 08:38 AM
Disc brakes don't involve moving a lot of fluid during the braking cycle. It's the pressure that makes you stop, and you can get the same pressure from a standard dual inline master cylinder as you can from a tandem setup.
Old 07-13-2006, 08:43 AM
staleg's Avatar
I understand.
Thanks for your answer.
Old 07-13-2006, 09:47 AM
302 Z28's Avatar
My 34 has 4 wheel disc brakes and I am using a 67 Corvette manual 4 wheel disc brake master cylinder. I see no need to complicate things by using two manual master cylinders. That year Corvette was offered with 4 wheel manual disc brakes and it weighed a lot more than a 34 Ford does
Vince
Old 07-13-2006, 07:20 PM
Wiki Edits: 27
2 master cylinders
The hot setup is two master cylinders with a balance bar between them so you can adjust for different tire sizes, front to rear weight load etc.. 427 cobra had that style and I pitted on the one that set the MIS track record Brice even adjusted it for street use with a passenger retired ford engineer
Old 07-14-2006, 07:01 AM
302 Z28's Avatar
Absurd IMO on a street car.
Vince
Old 07-14-2006, 02:27 PM
Darkman270's Avatar
Yep it is absurd but I'm tinkering with the idea also but for different reasons, My 57 F100 has a clutch M/C mounted beside the Brake M/C and they appear to be twins. Installing a Balance bar would be fairly straight forward. I'm running an automatic and will no longer need the clutch system. My project is a safety restomod and I am using the factory Y block. Under the hood will remain as stock looking as it can.
Old 07-14-2006, 03:59 PM
35chev/302gmc's Avatar
I use the willwood single pedal with the duel master set up and it works great. Stops my 3000# rod with very little efford.
1935 chevy,masters
Compressor - Single vs. Dual Stage cab Garage - Tools 28 09-06-2010 05:48 PM
Dual vs. Single Plane Intakes Ozz1967 Engine 8 12-23-2005 03:55 PM
single vs. dual tunnel ram upstand2 Engine 5 06-28-2005 05:30 AM
Single to Dual Master Cylinder swazo Suspension - Brakes - Steering 2 10-19-2004 09:00 AM
Single plane and duel plane manifold stonedchihuahua Engine 21 01-07-2003 12:56 AM
