20 year old Carter mechanical fuel pump leak? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2010, 08:16 PM
bubbahotep's Avatar
I did 2 WOT runs today in the street and lost power on the 2nd run, smelled gas, and headed home. My 383 stroker (350 block) has a Carter mechanical fuel pump which has to be a good 20 years old but has only 6500 miles on it which is the same as the engine give or take. It "was" leaking from the top half of the pump where you'd normally removed the 6 (I think it was 6) screws if you wanted to turn the position of the in/out openings and then reseal. Between the 2 halfs is a 1/8" rubber like gasket although I dont think its rubber only.
The leak appeared to be coming from the gasket and was pushing a good 1/2 gallon per minute. I took it apart, couldnt find any signs of cracks, resealed it using permatex reusable gasket sealer, and it still leaked although not as bad. From experience, is the gasket just dead? Its possible its just dry cause the car has roughly 6500 miles in 20 years. Can I replace that internal gasket or is a new pump in order?
Old 07-11-2010, 09:03 PM
ericnova72's Avatar
More for Less Racer
Probably just the rubber has died with age. Carter pumps like yours are rebuildable, they sell a kit for it.
Old 07-11-2010, 10:04 PM
bubbahotep's Avatar
Didn't know about the kit, thanks
Old 07-12-2010, 01:10 AM
Not sure on the price for the kits, but I just replaced my leaking carter pump (from the same spot as yours) for $18 at Baxter auto parts.
Old 07-12-2010, 06:01 AM
Irelands child's Avatar
Why fool around with it - you can buy a new one from Summit for $20 - $120 depending on what version you want : http://www.summitracing.com/search/Department/Air-Fuel-Delivery/Section/Fuel-Pumps-Regulators/Brand/Carter/Part-Type/Fuel-Pumps-Mechanical/Make/CHEVROLET/?Ns=Rank|Asc
You'll probably have to copy 'n' paste the link
Dave W
Irelands child
Old 07-12-2010, 06:28 AM
bubbahotep's Avatar
Mine is the higher priced one with a kit going for roughly $40. I can't find just the one gasket/diapragm part seperately.
What's the gph on the $18 version?
Looks like eBay is calling.
Old 07-12-2010, 12:27 PM
Not sure on the gph rating, but it is a direct replacement for the stock unit, part # m6626 (assuming you have an AT) Rings up on my receipt as "Carter SBC Musclecar Fuel Pump"
Old 07-12-2010, 01:40 PM
bubbahotep's Avatar
I found that part online (thanks) and that appears to be an oem match. Mine has npt fittings and comes apart in 2 places for positioning the inlet and outlet. I'd be pissed if that part outputs the same as the pricey one . The oem would fit my setup easily with no clearance issues
Old 07-12-2010, 04:22 PM
I remember seeing that one too, I think the price on it was around $37
No fuel to carb, do have fuel at pump inlet - replace? bruceg Engine 8 04-22-2010 08:41 PM
can i use a mechanical fuel pump on a 89 sbc warning Engine 1 09-24-2008 10:19 AM
Electric fuel pump shut-off mur39 Electrical 22 03-05-2007 05:48 PM
Which waterpump? Eagle1 Engine 5 08-06-2004 06:38 PM
Mechanical Fuel Pump Replacement Jag Daddy Engine 2 03-24-2004 01:09 PM
