Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 200-4R Build Finally Begins!
Old 01-13-2010, 10:55 PM
SSedan64's Avatar
SSedan64 SSedan64 is offline
87 was last year for the GN, 88 was last year for the SS.
You'll probably have better luck with the CZ code SS Monte core.
CR & KC code cores are good to work with also. Jakeshoe has experience with them, tuning them for higher rpm auto shifts using the CZ/SS code Governor. I think he said with CZ Gov, they shift around 6100-6200rpm.
The GN's BR/BQ codes seem to work best with the lower rpm turbo V6 engine from what I've read.
