Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 200-4R Build Finally Begins!
  #44 (permalink)
Old 10-21-2012, 07:38 PM
zildjian4life218's Avatar
zildjian4life218 zildjian4life218 is offline
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Well I got the transmission all taken apart today and found a couple blued pieces and a broken 1-2 accumulator spring. Any idea what would cause the spring to break? Also the Accumulator plate has some gouges in it im assuming from the broken spring. Should I replace this? I noticed pitting on a bunch of the steels. What causes this? Lastly I noticed some blueing on some hard parts. Can I get some input on if they need to get replaced or not. Looks like the forward clutch housing and the internal overdrive gear.
Thanks everyone!!
Name:	accumulator spring.jpg
ID:	68508   Click image for larger version
Name:	accumulator plate.jpg
ID:	68509   Click image for larger version
Name:	forward clutch housing blue.jpg
ID:	68510   Click image for larger version
Name:	overdrive gear blue_1.jpg
ID:	68511   Click image for larger version
Name:	overdrive gear blue_2.jpg
