200-4R Build Finally Begins! - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 10-15-2012, 01:15 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
I meant add to the equation as in add it to the amount of slippage..... I don't know why I worded it that way doesn't really make sense. But yes I agree with you that the higher stall the more slippage and will probably push me more towards running a lockup converter.
  #32 (permalink)
Old 10-15-2012, 06:53 PM
TexasT's Avatar
Did you ever wonder?
Last journal entry: New stuff came in the mail.
Originally Posted by zildjian4life218 View Post
Any input on this particular model of 200 4r? Again I have not seen a CHF on any of the websites I have looked at.
THM 200-4R Information
As posted earlier in post #14, this chart notes that the CH in an '88 model was behind a 4.3L V6.
  #33 (permalink)
Old 10-16-2012, 06:21 AM
Listen and Learn
Wiki Edits: 7
ah okay thanks. Idk why but I was looking for all three characters together and skipped right over that one. So basically this trans is not anything to get too excited over. what hard parts do you suggest I replace for this trans to last behind a sbc making about 400hp/tq(I would like to leave room for expansion... maybe a little spray in a future). I know the stator support and sun gear shell is a must. I have also heard that the forward drum can break but I never saw an estimated hp figure on when it will fail. I know ckperformance has a rebuild kit that includes a new forward drum and they rate it for 450hp.
  #34 (permalink)
Old 10-16-2012, 08:06 AM
SSedan64's Avatar
I recommend getting a Billet shafted Forward Drum & using CKs Shift Recal kit w/Billet Servo.
His #24RRK/SS Rebuild kit contains those 3 w/discount.
I'd also use a 10-Vane Rotor kit. The 13-Vane tend to break more easily at higher rpm & pressures.
www.CKPerformance.com
Depending on how much spray you use you may want to ask about the .555" TV & .400" Low/Reverse boost valves. They can be swapped inplace of the .500" & .300" size which are standard in the Recal kit.
The splines on the OD Carrier & OD Ring Gear are the next weak link, then the Input Shaft.
I have all 4340 Billet parts in my Trans except the Output Shaft, I don't think I'm pushing 800TQ I rollerized my own parts, easy if you have a Lathe.
There was a Suplement to Chris' 2004R Manual but, I don't know if He has anymore or if they're available now. A Member on TB.com asked but, hasn't received an answer.
  #35 (permalink)
Old 10-16-2012, 08:21 AM
Listen and Learn
Wiki Edits: 7
Thanks for the reply! I was starting to lean more towards the 24RRK/SS rebuild kit after reading about the weakness in the forward drum.
I haven't really been able to reliably drive my car for the past three summers so I don't mind throwing extra money at the good components to make sure it lives and I can really rack up the miles this upcoming summer.
Would you recommend this pump or any others? TH-200 4R Hi-Performance 10 Vane Pump, this is a must for high RPM engines I believe CK in their Street strip trans uses a new GM pump. Also do you think the OD carrier and ring gear will be okay say around 450-500hp? If I spray it I don't think I would go more than 100-150 but then again im sure it will be tempting to not just throw the biggest jet in there and hang on lol. I think Art Carr did a carcraft article and said around 550 these start to fail but of course vehicle weight and tq play a roll on this also. After I put it together I am gonna also find a transmission dyno to run it and make sure everything works good before I put it in the car.
  #36 (permalink)
Old 10-16-2012, 08:44 AM
SSedan64's Avatar
That's a Pump rebuild kit, not a Pump. It's also a little pricey. If the Pump needs rebuilding I recommend buying a rebuilt one. It's not possible to get the clearances right unless you have a Lathe.
CK has reasonably priced HP Pumps. > www.CKPerformance.com
Pump rebuild/upgrade Info starts about 1/4 way down Pg.
ATTENTION!!!! NEW VERSION!! Strengthening The 2004r | TurboBuick.Com
I'd wait on the Billet OD parts. You can buy them later on if needed.
Chris/CK has a Trans Dyno.
  #37 (permalink)
Old 10-16-2012, 09:00 AM
Listen and Learn
Wiki Edits: 7
Awesome thanks for the heads up on the pump. Ive never had any experience with this stuff so its great to have some guidance. I may just buy a whole new pump from CK that way I don't have to screw around with a used pump and its setup the way the recommend. Plus it comes with the larger boost valve and the heat treated pump stator I will need. Only problem is Im on the other side of the state so I imagine shipping would be a fortune and its probably about a 6hr drive one way. But then again I may not be able to find something local so who knows. I will have to figure that out when the time comes I guess.
  #38 (permalink)
Old 10-16-2012, 07:05 PM
TexasT's Avatar
If you plan on dual feeding you NEED the billet forward drum.
Scott McClay Transmissions, 200-4R Drum
200-4R Components
http://www.jakesperformance.com/200-...uild_Tech.html
TH200-4R Rebuild - Dynotech Performance - GM High-Tech Performance Magazine
200R4 Rebuild
Here are some links. I have a bunch more that include suppliers that have parts.
I started a project thing on this site and included some pix. I am moving along on my rebuild but my time is limited as is my %. Did you contact David Husek? He is a noted builder full of excellent info.
  #39 (permalink)
Old 10-16-2012, 07:09 PM
TexasT's Avatar
How to Build a TH200-4R for 1,000 Horsepower - Car Craft Magazine
  #40 (permalink)
Old 10-17-2012, 05:24 AM
SSedan64's Avatar
Not many put much stock in Arts builds anymore. Those Hardened Forward Drums are polished Turds.
Dave is a good source of Parts & Info, also probably cheaper than CK.
Turbo Buick Performance
  #41 (permalink)
Old 10-17-2012, 09:28 AM
Listen and Learn
Wiki Edits: 7
Thanks for all the links TexasT. Those will def come in handy when it comes time to order parts.
SSedan I will definitely check out that link also. Hopefully this weekend I can pull the rest of the guts out of the trans and see what else needs to get replaced and is worn etc. Maybe get the case out to get cleaned up so I can have it painted and be reading for assembly whenever that happens.
  #42 (permalink)
Old 10-20-2012, 06:45 AM
TexasT's Avatar
200-4R Transmission Parts GM - rear wheel drive
  #43 (permalink)
Old 10-20-2012, 08:56 AM
Crosley's Avatar
Wiki Edits: 1659
I work with a fellow that grew up working at the first Art Carr location. He even worked at the second location after Art sold the place to the business investor guy that moved the business to Las Wages area. He has stories about his days there.
  #44 (permalink)
Old 10-21-2012, 07:38 PM
Listen and Learn
Wiki Edits: 7
Well I got the transmission all taken apart today and found a couple blued pieces and a broken 1-2 accumulator spring. Any idea what would cause the spring to break? Also the Accumulator plate has some gouges in it im assuming from the broken spring. Should I replace this? I noticed pitting on a bunch of the steels. What causes this? Lastly I noticed some blueing on some hard parts. Can I get some input on if they need to get replaced or not. Looks like the forward clutch housing and the internal overdrive gear.
Thanks everyone!!
Name:	accumulator spring.jpg
ID:	68508   Click image for larger version
Name:	accumulator plate.jpg
ID:	68509   Click image for larger version
Name:	forward clutch housing blue.jpg
ID:	68510   Click image for larger version
Name:	overdrive gear blue_1.jpg
ID:	68511   Click image for larger version
Name:	overdrive gear blue_2.jpg
  #45 (permalink)
Old 10-21-2012, 07:41 PM
Listen and Learn
Wiki Edits: 7
Hers some more pictures.
Name:	forward clutch pitting_1.jpg
ID:	68513   Click image for larger version
Name:	forward clutch pitting_2.jpg
ID:	68514   Click image for larger version
Name:	forward clutch pitting_3.jpg
ID:	68515   Click image for larger version
Name:	steel pitting.jpg
finally finished chevy 350 build redneckrodder Engine 7 05-30-2011 06:03 PM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Engine build ideas Rug Engine 23 12-25-2006 01:39 PM
350 build finally.... Whadya think?? Meangreen Engine 16 12-04-2003 08:26 PM
Finally decided on an engine build up! Adrenaline_Fiend Engine 2 10-20-2003 09:43 PM
