200-4R Build Finally Begins! - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2010, 07:00 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Hey everyone. I am Finally ready to start tearing down the trans for rebuilding. I am looking at picking up a core for $100 out of an 88 monte carlo ss, or my friend has one with a fresh rebuild in it that wants to trade for a set or rebuilt vortec heads i have. I have about $300 into the heads. Do you think I could pick up the trans that is rebuilt and maybe put in a shift recalibration kit along with a new servo? Originally i was gonna just get a core and rebuild it myself with CKPerformance MASTER REBUILD KIT #24RRK/C. http://www.ckperformance.com/resourc...BUILDKITS.html Included in this kit is
GENERAL OVERHAUL KIT #24RMRK
6 piece washer kit with 2 oversize sun shell washers
12 piece bushing kit
4 piece rear section selective end play washer kit
15 piece center section selective end play washer kit
All friction and steel plates
Updated 3 friction 4th clutch pack
6 friction 3-4 cluch pack with red lined racing frictions
Alto oversize red lined racing band with welded anchors
High flow filter assembly.
SHIFT RECALIBRATION KIT #24RSRK/A ($129.00)
HEAT TREAT PUMP STATOR TUBE #24RCC/PST ($34.99)
HEAT TREATED SUN GEAR SHELL #24RCC/SGS ($34.99)
HEAVY DUTY LOCK UP SOLENOID #29.99
I am gonna be putting about 400hp/tq to the trans behind a vortec sbc355. Thanks for all the input everyone!!!
Old 01-13-2010, 08:45 PM
S10xGN's Avatar
Gotta love a turbo!
Thought '87 was the last year for the MCSS... If you can verify it's from a SS, it's a great core to start with. At least you won't have to buy a (better) valve body. I'd be inclined to go that way with Chris's kit.
Russ
Old 01-13-2010, 09:46 PM
Listen and Learn
Wiki Edits: 7
You might be correct on it being an 87. I assumed it was late 80s from the body style. From what I have read if I do go with a core then rebuild it I should look for either a grand national trans, a monte carlo trans, or a turbo trans am trans. They have better valve bodies and servos from the factory. I am a little iffy about getting a trans that is already rebuilt that i am gonna tear into to replace parts anyways. Plus the kid that "rebuilt" it says those trans hold 650hp from the factory without any modifications lol. So who knows how good he did rebuilding it.
Old 01-13-2010, 10:55 PM
SSedan64's Avatar
87 was last year for the GN, 88 was last year for the SS.
You'll probably have better luck with the CZ code SS Monte core.
CR & KC code cores are good to work with also. Jakeshoe has experience with them, tuning them for higher rpm auto shifts using the CZ/SS code Governor. I think he said with CZ Gov, they shift around 6100-6200rpm.
The GN's BR/BQ codes seem to work best with the lower rpm turbo V6 engine from what I've read.
Old 01-13-2010, 11:02 PM
Listen and Learn
Wiki Edits: 7
alright good I will get the code of the trans and hopefully post pics of the tear down process here soon.
Old 01-14-2010, 12:02 AM
larrym's Avatar
Enjoy the process its a fun project and very satisfying when complete.
Old 01-14-2010, 08:10 AM
Listen and Learn
Wiki Edits: 7
I am probably gonna order the manual from ckperformance so the rebuild goes a little smoother.
Old 01-14-2010, 08:18 AM
artsvettes's Avatar
Money well spent. It is an excellent manual and Chris is very helpfull with questions
Old 01-14-2010, 08:21 AM
I'll be watching this thread with interest. I want to do this upgrade for my 69 GTO resto-mod. It is just above stock in terms of power and I want to shed the huge, inefficient TH400. Before the flames begin, I know the 400 is virtually indestructible, but I want Overdrive and I like the 200's gear spread.
Whats everyone's thoughts on a 200 from a late 80's Cadillac? I was at the u-pick/u-pull about 2 months ago, and there were several Cadillacs with a 200 in them. They also sell these dirt cheap because...u have to pull it.
-J
Old 01-14-2010, 10:25 AM
artsvettes's Avatar
Not to discourage you from using the caddy trans I believe it is the AA code. The main diffrence is the
Valvebody and calibrations
Governor
Intermediate apply piston
Spring calibration 1-2 and 3-4 apply pistons
Torque convertor
As stated the CQ and CZF will be the easiest and reasonable core to find out of all the performance 2004r.I have scored a few off of craigslistq
Old 01-14-2010, 09:42 PM
jakeshoe's Avatar
The Cadillac AA code VB works very well for retrofits.
Old 01-15-2010, 10:11 AM
Listen and Learn
Wiki Edits: 7
Hey Jake, Do you also have a rebuild manual I can buy? I am def getting the one from CKPerformance but you can never have enough reading material.
Old 01-20-2010, 02:51 PM
Thanks for the info. Can the codes can be found on the door tag?
-J
Old 01-20-2010, 03:17 PM
SSedan64's Avatar
2004R / 200R4 Trans Tag Codes
Codes are on metal tag on passenger side tail of Trans and Ink stamped on Valve Body.>> http://web.archive.org/web/200701281.../thm2004r.html
Old 02-08-2010, 09:08 AM
Listen and Learn
Wiki Edits: 7
I found a 200-4r on craigslist in my area. The guy wants $800 for it and says its built for 500hp. It comes with a stock GN converter that I will prolly sell cause I will need a stall speed of around 3000. But the rest of the trans has hardened sun shell upgraded clutches with additional clutches ,bearings instead of bushings ,b&m shift kit ,upgraded valves , never installed. I am still waiting on the code off the trans and he said its a BOP bell housing. Is this worth it? I would prefer to get a core and put the rebuild and shift kit from CK in it.
finally finished chevy 350 build redneckrodder Engine 7 05-30-2011 06:03 PM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Engine build ideas Rug Engine 23 12-25-2006 01:39 PM
350 build finally.... Whadya think?? Meangreen Engine 16 12-04-2003 08:26 PM
Finally decided on an engine build up! Adrenaline_Fiend Engine 2 10-20-2003 09:43 PM
