200 4r Converter Lock Up - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-01-2008, 07:30 PM
I am replacing the 350 tranny in my 37 Ford with a 200 4r. What is the best recommended way to control the converter lock up?
Thanks
Old 10-01-2008, 09:00 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
http://www.jegs.com/p/TCI/748599/10002/-1
Old 10-01-2008, 09:27 PM
redlightning's Avatar
I had one in my 80 camaro for awhile.I just used a toggle switch.It worked fine.
Old 10-02-2008, 12:59 AM
SSedan64's Avatar
If you only plan to use the TC lockup in 4th gear such as on the freeway for gas mileage, the toggle switch method Redlightning mentioned will work. 12Volts to pin-A on the 4-pin connector, left side of trans.
This is a very cheap kit that only activates when it senses line pressure from the 4th gear pressure switch. It can be located externally by the port on right side of trans or internally on Valve body inside trans pan.
http://cgi.ebay.com/ebaymotors/700R4...QQcmdZViewItem
Old 10-02-2008, 07:44 PM
Which is Best
I only want lock up in 4th gear, and don't want to have to remember to do anything manually.
So which is the best, the TCI or toggle solution?
The cost different is not problem.
Thanks, for the suggestions.
Old 10-02-2008, 09:52 PM
The TCI kit works automatically without having to do anything manually. Automatically engages when in fourth unless engine load is high (low vacuum), or brake pedal is pushed. Will feel like a subtle extra gear.
The manual override to disengage is useful if you are in slow traffic or on winding country roads. Manually disengage OD so engine doesn't lug or keep going into and out of OD.
John
Old 10-02-2008, 09:56 PM
SSedan64's Avatar
If cost in't a factor get one of the complete kits. They come with vacuum switch, oil pressure switch & all wiring/plugs etc.. Several companies make them. The brake light switch disengages lockup when you press the peddle. The vacuum switch engages lockup when vacuum is high at light/part throttle and disengages lockup when vacuum drops with more throttle opening. Adjustable vacuum switches are available to fine tune lockup also.
TCI Kit
http://store.summitracing.com/partde...5&autoview=sku
Same TCI Kit on Ebay
http://cgi.ebay.com/ebaymotors/TCI-2...QQcmdZViewItem
B&M Kit has lighted toggle switch & lockup can be switched off.
http://cgi.ebay.com/ebaymotors/B-M-8...QQcmdZViewItem
Old 10-03-2008, 06:46 AM
345 desoto's Avatar
Location: Skaneateles, NY Summer/Port St.Lucie, FL Winter
Go for the automatic switch. It allows the tranny to operate the way it was intended. It's not like you need to buy one every week...it's a small, one time expense...
Old 10-03-2008, 09:53 AM
PutPut72's Avatar
Earplugs are in the glovebox
This one is about double of the ones you are looking at, but I have one in my 72 Chevy C-10 with a 700R-4, and I love it. It has a rheostat that allows you to set the speed at which the converter locks up, and it has a manual override button if you don't want it to come on. So whatever gear you are in, when you hit the MPH that you have set with the dial, the converter will lockup. JMO but I love it.
Also just so you know, some of the kits that were suggested you have to drop the transmission pan and install a new pressure lockup switch on the valve body, (kind of a pain if you don't want to do it). But their are some, like the one that I suggested, that you only have to plug it in on the side of the trans, add the electric sender inline with your speedo cable (its just an inline type, very easy and quick),route and mount the wires and box and supply it with 12v, very easy to install.
TCI Stall Converter - Blown SB 68NovaSS Transmission - Rearend 10 09-09-2008 12:42 PM
700r4 lock or unlock t converter JDS539 Transmission - Rearend 3 07-24-2008 09:35 PM
TH350 gap between converter and flexplate QUESTION chrisgarrison Transmission - Rearend 6 12-26-2004 11:32 PM
how do i know if i have a lock up converter? 72HeavyChevy Transmission - Rearend 1 01-01-2003 02:33 PM
TH350 lock up wiring JMAC Electrical 0 06-14-2002 10:10 AM
