200 4r deep pan question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-20-2013, 12:26 PM
I have acquired a second deep aluminum pan for my stand by tranny, and I noticed that between the small and large pan pockets there is a thick wall. Could I drill a hole in this wall and relieve that fluid to pass to the large pan opening? Or is there a good reason not to do this? I saw a large steel deep pan that didn't have this pocket at all under the governor portion of the pan.
Old 07-20-2013, 02:38 PM
Yep, after studying it and talking to my brother, found out that it wouldn't do any good, because of the fluid depth to nearly the pan rail. The large steel pan uses the large single opening for fluid volume.
Old 07-21-2013, 10:19 AM
S10xGN's Avatar
Gotta love a turbo!
I drilled a 1/4" drainback hole, simply for whenever I need to remove the pan for maintenance...
Russ
Old 07-21-2013, 01:30 PM
I have now done the same thing. I guessing that there is half a quart of fluid that stays trapped and if I change things, i'll have to deal with that mess no matter what I do every time I change things. I'm going to put this pan on in a couple of days when I change my speed o gears. Then i'll drill the other pan after I clean up the mess, because I know that that half quart is going to drip a lot.
deep 200 4r pan dwwl Transmission - Rearend 20 05-16-2013 06:36 PM
TB 400 and new deep pan bigiron40 Transmission - Rearend 11 04-20-2010 10:43 AM
T-400 deep pan cletus van damme Transmission - Rearend 3 10-22-2009 05:26 PM
200-4R Deep Pan Regal Beagle Transmission - Rearend 2 06-16-2009 02:15 AM
C-4 Deep Pan nova69 Transmission - Rearend 1 05-30-2005 08:28 PM
