Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 200-4R durability questions
Old 11-18-2012, 08:51 AM
beachbum0's Avatar
beachbum0 beachbum0 is offline
I had a tci valve body put into a 700r4 once because the cable wasn't adjusted correctly and lost 3rd and 4th clutches,fast, about 2 miles. The valve boby would keep 200 lbs of pressure even if you lost elect.power to the trans.I never lost 12 volts to trans so i don't know if it worked. Now that I know the 200, [I like the gears], will work I might call them up to see if thay offer one for this trans.
