Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 200-4R durability questions
Old 12-13-2012, 06:45 AM
dwwl dwwl is offline
if you use the two pan trick on the 200 4r and the 4l60 filter, make sure you donty just have the filter hanging there that is why i use some form of spacer on the bottom of the pan so thke filter has something to set on. that way the filter get oil since it a bottom feeder
