200-4r early shifts when hot!
Hey guys, I have a 200-4r tranny behind a stock 305 86 monte SS. Everything is stock, stock, stock.
I just bought the car. when the tranny is cold it shifts fine, no slip, proper kick downs, etc. When the tranny gets hot (2-3 miles+), i notice the shifts get stacked on one another and i'm in 4th gear at 20mph. also, when stopping, it's holding onto engine and the motor almost stalls. now I know the importance of the TV cable and I've checked it 10 times and am "sure" it is set correctly - being that it shifts properly when cold i'm leaning away from TV cable issues. is this pointing towards a converter problem? i dont have a pressure gauge and haven't checked pressures - hoping to maybe get an idea before i go that far or even drop the pan. but i know that knowing the pressures is very important. thanks for any help! James |
it sounds like more of a valve body problem.....it's possible that the throttle valve is sticking towards the closed position....try this..when it starts acting up,take off at about 1/2 throttle...if shifts are still stacked,my money would be on that being the problem......or you can try this..TURN CAR OFF...and mash the pedal to the floor a few times...start car and drive it to see if it freed up the valve and it shifts normal,even if it's for a few shift cycles....the engine wanting to stall when coming to a stop is a characteristic of a bad[sticking open] lock up solenoid.Its not the converter...they are stupid,and have to be told when to be applied,and when not to...thats where the solenoid comes into play.
Hmm. I have a 700R-4 that shifts late when cold. After an hour of driving, the shifts are fine. But the full-throttle up-shifting is exactly as above: early when hot, fine when cold.
9 out of 10 erratic shift concerns in 200-4R's and earlier 700's are directly related to a quirky throttle valve in the valve body....the fix is to install a special aftermarket spring behind the valve to prevent it from sticking.
Sounds great guys thanks, I just got a tcc solenoid and when I have the cover off I'm going to see if the throttle valve is moving right. There is little tension on the tv cable so maybe the spring is weak? I'll check back
Ok I dropped the pan to replace the solenoid. checked valve plunger and it's moving freely (but i guess that could change when it's hot).
rick427 - i push in on the plunger till it bottoms out, then release - and it doesn't snap right back out but probably takes 1 full second to fully come back out. is this normal? a stiffer spring would shoot it back out faster, but i know it's moving some fluid around so maybe it shouldn't shoot back out as fast as i'm thinking. |
when you slowly push in the plunger,it should go in, and return, smooth as silk ,with no hesitation or resistence,other than the spring tension when pushing it in...that plunger is in an aluminum housing,and it shouldn't have any side to side movement as you're pressing it in...what you cant see,however, is the other valve on the other side of the spring...but if that sticks,that usually gives you late shifts....but if the plunger valve is hanging up in the aluminum housing,or not making a smooth full travel, it will give you early/stacked shifts....I would replace that assy on all my rebuilds,as well as place a spring behind the valve that you can't see...because prior to that,even tho they were working nice on the bench,once they got warm on the road they would start hanging up....if your plunger is sticking or rachety,it should be replaced
X2^^, good info one the TV/ThrottleValve above.
Good TCC Solenoid Info >> http://www.montecarloss.com/TCC_Solenoid.html |
so I took pan off and replaced TCC solenoid. checked valve body plunger and it seemed smooth and tight (no free-play in radial direction). the TCC solenoid fixed the problem!!! shifting right on the money at half throttle, downshifting properly, etc. thanks for all of your help!
2004-R spring
Does anyone have a part number or vendor that has the extra spring for the valve body to eliminate the piston sticking ? Thanks
Check with Sonnax.
http://www.sonnax.com/product-lines/...%5Bunit%5D=245 |
| Early Ford Spindles fitting early Ford axles | pasadenahotrod | Suspension - Brakes - Steering | 3 | 08-14-2012 07:20 PM |
| Early shifts on transplanted 1963 Ford transmission | grobb284 | Transmission - Rearend | 4 | 10-09-2011 05:19 PM |
| early hemi cuda project! need help shipping engines and building an early hemi | thecountmc | Hotrodders' Lounge | 13 | 12-03-2007 05:21 PM |
| early comet engine swap (or early mustang) | REALGONEKATT | Engine | 14 | 11-04-2007 06:15 PM |
| early shifts on th-350 | johnsquicks10 | Transmission - Rearend | 5 | 05-05-2005 08:17 AM |
