200-4r identification - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-11-2010, 12:18 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Hey everyone im looking at buying a core to build a transmission for my 86 cutlass. Found a guy on craigslist near me with a 200-4r out of an 87 cutlass. He said the ID number on it is 309-872KJF1555 can anyone tell me if this is a good core? Thanks
Old 10-11-2010, 12:22 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
Pictures of transmission pans,
Rich
http://700r4.com/trans/comparrison.html
Old 10-11-2010, 12:35 PM
Listen and Learn
Wiki Edits: 7
I was wondering more if someone can tell me if this is a good canidate to build up. I know some 200-4r trans are better than others this http://web.archive.org/web/200701281.../thm2004r.html is what im going off of as of now and according to the number i got something is wrong
Old 10-11-2010, 02:16 PM
Hi,
I think you'd do better over at turbo Buick, 200-4Rs is what came in theses cars,
Rich
copied from turbo Buick, PM this fellow over there, you may have to join the site?
MeanBuicks's Avatar
MeanBuicks MeanBuicks is offline
Scaring the neighbors!
Trader Rating: (0)
Greg Friend
GSC@ #618
Friends' Garage --> Be sure to stop in my garage sale.
1987 Grand National Astroroof
1987 Grand National GNX'd << stolen & stripped to hell 4/19/06; R.I.P
1967 GS400 convertible
1984 Cutlass Supreme Brougham | 1992 Custom Cruiser Wagon
Nationwide Insurance SUCKS!!!
Lakeland International Raceway Ghost Track
Old 10-11-2010, 02:37 PM
SSedan64's Avatar
What do you mean, something is wrong? That code list isn't complete.
KJ code = 307 Y engine w/3.08/3.23 rear Gear. The KB code probably came with a different rear gear ratio.
If your gonna use this connected to a SBC engine it will be fine.
Build it with a HP rebuild kit, w/CK Shift Recal Kit & use a GN, SSMonte or 442 Gov for 6000rpm & up Auto shifts. Chris, Jake, Bison or Lonnie on TurboBuick.com can help with Vbody mods needed, may need to change Line Bias spring also.
I posted some links there today about Higher rpm shifts.
Todd
Many use the KC Vbody & GN Gov for higher rpm Auto shifts = 6000rpm.
Old 10-11-2010, 02:50 PM
Listen and Learn
Wiki Edits: 7
Todd
My bad i was looking at the wrong digits lol. its gonna go behind a 400hp sbc. I was thinking MASTER REBUILD KIT #24RRK/C http://www.ckperformance.com/resourc...BUILDKITS.html
and of coarse....
http://www.ckperformance.com/resourc...CALMANUAL.html
Old 10-11-2010, 03:09 PM
SSedan64's Avatar
I don't think Chris has anymore Manuals available, an ASTG manual & video would be good.
This link has several sites w/build Info I listed >> http://www.turbobuick.com/forums/tra...ml#post2568243
Old 10-11-2010, 03:35 PM
Listen and Learn
Wiki Edits: 7
does anyone think that the rebuild kit MASTER REBUILD KIT #24RRK/B will hold up to my power goals?
Old 10-11-2010, 03:47 PM
SSedan64's Avatar
I can't remember what they are? Use, HP/TQ?
Old 10-11-2010, 03:50 PM
Listen and Learn
Wiki Edits: 7
IT will be street/strip. Going in a 86 cutlass Should be making at the crank like 400hp/400tq.
Old 10-11-2010, 03:58 PM
SSedan64's Avatar
IT will be street/strip. Going in a 86 cutlass Should be making like 400hp/400tq.
Should be but, Inspect the Stator Support for wear, 87 should already have the Hardened one.
The weak link is the Shaft in the Forward Drum. The Billet Shaft Forward Drum is good insurance, not cheap tho'. CK usually has sale around Christmas time. Usually about $80-$100 off. http://www.ckperformance.com/resourc...OMPONENTS.html
Inspect all Planetaries & O/D Ring Gear splines.
Keep an eye out here for sale prices>> http://www.turbobuick.com/forums/transmission-talk/ & here >> http://www.turbobuick.com/forums/advertiser-specials/
Old 10-11-2010, 04:01 PM
Listen and Learn
Wiki Edits: 7
K thx. Does anyone make trans brakes for these trans?
Old 10-11-2010, 04:11 PM
SSedan64's Avatar
Oh Yeah!
You can get a Manual type called "Stage Right" replaces the Manual Shift Valve in Valvebody, comes w/Sep. Plate etc..
Or you can get the more expensive Electric Brake.
http://www.extremeautomatics.com/pro...004rparts.html
If you're gonna run a T-Brake you should get a 4340 or 300M Billet Input Shaft also. + A good Driveshaft & U-Joints and strong Rear.
Stage Right, place Shifter in Low/1, mat gas peddle, slap shift to 2nd or D to release. You do lose the Manual Low gear function as this locks the Trans in R & D simultaneously.
Electric Brake works off a switch. No loss of Low/1st gear.
Old 10-11-2010, 04:15 PM
Hi,
Read about the parts in this trans. & compare it with the kit your looking at.
http://www.transmissioncenter.net/200-4r.htm
Old 10-11-2010, 04:18 PM
SSedan64's Avatar
This is a good comparison of many builds.>> http://www.extremeautomatics.com/eavscomp/th2004r.html Look for E/A to PATC
Water in 200 4r 84'Monte Transmission - Rearend 12 08-19-2009 09:20 PM
T-400 to T-200-4r speedometer WAY off 60smotorhead Transmission - Rearend 5 08-07-2009 03:14 AM
Corrected Write Up for 200 4R Lock Up Ted's37 Transmission - Rearend 0 07-17-2009 04:06 PM
200 4r Temperture Ted's37 Transmission - Rearend 3 03-26-2009 11:04 AM
200 4r 1st to 2nd shift Ted's37 Transmission - Rearend 7 11-26-2008 10:55 PM
