-   -   200 4R internal wire harness (http://www.hotrodders.com/forum/200-4r-internal-wire-harness-220927.html)
40 grey 06-24-2012 01:55 PM
Hey all, I have done a search on this topic and have not really found an answer. Question: Is the internal wire harness (on the valve body) in a 200 4R made of special wire to stand up to the oil and heat? I have a 200 4r that is rebuilt but I noticed that the harness is slightly crushed (pan was dented into it). Is there special wire that gets used for this application? Thanks.
BigChevyFTW 06-24-2012 11:10 PM
the wires you want are for the TCC lock up function
tell them you want the solenoid wire harness you can get it at bulkpart.com
here is a link to them
http://www.bulkpart.com/2/product/20...d/T54425B.html
S10xGN 06-25-2012 09:10 AM
Dunno, but one thing to keep in mind is that there are numerous different harnesses for this transmission depending on year, make and model if you go hunting for a replacement. For patching your existing harness, I'd get some scrap auto wiring from a junkyard before buying any wire from a parts house (junk!)...
Russ
mmerlinn 06-26-2012 01:57 AM
Russ
I only know of two different wire looms for the 200-4R, a 1-wire and a 2-wire.
Maybe you are thinking of the 700-R4 which has about 20 different wire looms identified by the 4 digit number on the colored plastic spool for the solenoid wires..
S10xGN 06-26-2012 08:08 AM
The back few pages of the ATSG manual show way more than two... All have TCC wiring, some had 3rd gear solenoids, some had 4th gear solenoids, some had both, some were in different places, etc.
Russ
40 grey 06-26-2012 08:47 PM
Thanks for the responses. I dont need to replace the whole harness necessarily, but may just solder in new wires. I guess I will use good GXL or equivalent wire.
mmerlinn 06-27-2012 01:13 AM
Russ
I guess I will pay more attention when I dig into 200-4Rs in the future.
