200-4r lockup w/out rewiring? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-03-2009, 11:39 AM
Thommyknocker's Avatar
LOLLERS
Last journal entry: new toy
Is there a way to lock up the converter with out rewiring inside the transmission?
I just got done putting a 200-4r in my '50 chevy sedan. It replaced a shot th350, which made it really easy.
The 200r4 is out of a 1985 cadi, code A-A IIRC.
I've found all the information for the vac switch, brake light switch and manual switch, but they are pritty vauge, for a 700, or show how to rewire the trans.
If someone knows the connector pin letters for hot and ground, that's about all I think I need
Sorry if this has been discussed, I couldn't find what I was looking for.
Thanks
Thom
Old 09-03-2009, 02:14 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Old 09-03-2009, 03:05 PM
LOLLERS
Than you.
But does the second picture (internal wiring) show modifications required, or how they are actually wired?
Old 09-03-2009, 03:18 PM
Thumpin455's Avatar
Ask me about Ethanol
Last journal entry: 65 GTO
Originally Posted by Thommyknocker
Than you.
Itst how its actually wired. All you really need is the 12v source to the pin for lock up. Dont forget to unlock it before you stop at a light.
Old 09-03-2009, 09:49 PM
artsvettes's Avatar
I would suggest you drop the pan and see how it is internally wired. The tCC soleniod coud be a 1 wire ot 2 wire and will dictate which way it will be wired.
Willys36 wiring diagram is a good one and is using the double normally open pin switch. The stock 2004r uses a single pin normally open self grounding. You can run off the brake switch if you put a relay in running through the normally closed contacts
Old 09-04-2009, 09:57 AM
LOLLERS
So all tranny's arnt wired the same.
That's why the web is so vauge,
Bummer.
Thanks for all the help.
Thom
Water in 200 4r 84'Monte Transmission - Rearend 12 08-19-2009 10:20 PM
T-400 to T-200-4r speedometer WAY off 60smotorhead Transmission - Rearend 5 08-07-2009 04:14 AM
200 4r Temperture Ted's37 Transmission - Rearend 3 03-26-2009 12:04 PM
200 4r 1st to 2nd shift Ted's37 Transmission - Rearend 7 11-26-2008 11:55 PM
200 4r Converter Lock Up Ted's37 Transmission - Rearend 8 10-03-2008 10:53 AM
