200-4r lockup wire diagram questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2012, 08:37 PM
packratwrecker's Avatar
Too many hobbies!
I wanted to do a 1st gear lockup, for winching through the transfer case mounted pto. I was told by a transmission shop, that 1st gear lockup is impossible, due to the fluid flow. Beyond that, he couldn't say without looking.
found all kinds of info on 700r4 wiring, but very little on 200r4 internals.
Old 02-09-2012, 09:05 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
GM did not provide oil pressure in 1st gear for lock up in the design of 200-4r or the 700r4 trans.
