Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 200-4r questions looking to build up
Old 02-06-2013, 11:16 AM
dwwl dwwl is offline
OK. Now set down for the day at the old computor and research all the 200 4r tranny cites you can. Every time you see something that you want to know or use later, copy it/in paper form. then you will have it for reference. My file must of use a rem of paper. I know everyou tells you that you have to have special tools to take them apart and put them back together. I didn't. I looked at the type of tool they used and substituted something else. If you can do that, then you must be able to think on you feet. I used a short piece of top chain link fence rail with the male end to put in the support to rock it loose and out. Worked like a charm. When rebuilding the pump, I didn't have the large clamp to hold the two halves together when you bolt it back together. I used a very long sign clamp that i got years ago, it looks like a very wide, long radiator clamp. Good luck from Atlantic Ia
