200-4r questions looking to build up - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-06-2013, 11:00 PM
gearheadslife's Avatar
MentalMuffinMan
doesn't matter, it they didn't upgrade some hard parts, spend the 65 bucks get the book, it'll show you what needs to be chaned as your power level goes up..
this is what CKP does to make it live behind up to 500hp/500ft lb torque
The 2004R STREET/STRIP TRANSMISSION is reccomended for most high performance street and strip cars producing up to 500 horsepower/500lbs. ft. and weighing up to 3500 lbs.Perfect for low 11 second TURBO BUICKS,as well as all small and big block Buick,Cadillac,Chevrolet,Oldsmobile and Pontiac vehicles.All of our 2004R transmissions are in car tested and calibrated prior to shipment.The main mechanical failure in the 2004R trans is the forward drum.Our units come with this item STANDARD,not as an option.Although we have had cars go deep into the 10 second zone with this trans the durability of the overdrive section becomes questionable.When these parts break the vehicle will not go forward or reverse.For applications over 500 horsepower/500lbs. ft. and 9 and 10 second et. capable cars look into the 2004R PRO STREET/STRIP TRANSMISSION packages.Look over the build sheets and compare our builds to others based on components,not the "STAGE" designation.You will not find a similar trans at a lower price anywhere.
COMPETITION COMPONENTS
E4340 STEEL BILLET SHAFT FORWARD CLUTCH DRUM.
E4140 STEEL BILLET BAND ANCHOR PIN.
SUMP EXTENDER WITH BOTTOM FEED FILTER
PERFORMANCE INTEMEDIATE SERVO ASSEMBLY.
HEAT TREATED STATOR TUBE.
HEAT TREATED SUN GEAR SHELL.
PINNED GOVERNOR SPRING ELIMINATES GOVERNOR SPRING EJECTION
All of our billet competition component are manufactured in house on HAAS CNC equiptment.
CLUTCH AND BAND UPGRADES
SOLID TEFLON SEALING RINGS INSTALLED AT ALL LOCATIONS.
ALUMINUM FORWARD CLUTCH PISTON.
ALL NEW CLUTCHES AND STEELS.
ALTO WIDE RED 2ND GEAR BAND.
UPDATED 3 CLUTCH OVERDRIVE PACK.
.250" THICK STEEL DIRECT CLUTCH PRESSURE PLATE.
DUAL FEED DIRECT CLUTCH TRIPLES DIRECT CLUTCH APPLY PRESSURE.
PUMP MODIFICATIONS
BRAND NEW BLUEPRINTED GM FRONT PUMP.
.555" CNC MACHINED TV BOOST VALVE.
.400" CNC MACHINED INTERMEDIATE BOOST VALVE.
MODIFIED PRESSURE REGULATOR VALVE.
HIGH RATE PRESSURE REGULATOR VALVE SPRING.
PORTED PUMP DRAINBACK PASSAGES.
INDUCTION HARDENED STATOR SUPPORT.
STEEL PUMP VANE RINGS.
HIGH TENSION PUMP SLIDE SPRINGS.
INCREASED LUBE OIL TO REAR PUMP THRUST WASHER.
ROLLERIZED COMPONENTS
ROLLERIZED CENTER SUPPORT.
ROLLERIZED LO/REVERSE CLUTCH HOUSING.
ROLLERIZED REAR RING GEAR.
Over time the factory metal thrust washers wear and as a result increase operating clearances and send debris through the transmission.All metal thrust washers in the transmission are replaced with high capacity low drag needle bearing assemblies.This is a time consuming process but definately beneficial for a performance transmission build.Internal components are machined in a lathe to create pockets for the bearings to locate in,as well as generate proper clearances.These bearings also reduce internal friction.This results in lower thrust surface operating temperature,and reduced horsepower loss.
CALIBRATION UPGRADES
EXCLUSIVE CK PERFORMANCE SEPERATOR PLATE
DIRECT CLUTCH CORRECTION PACKAGE
RECALIBRATED VALVE BODY AND GOVERNOR
Valve body is completely disassembled ,all parts are cleaned and polished,mating surface is decked and all circuits are then pressure checked to verify proper function.
Over 20 years of research and development have resulted in the ultimate combination of performance and component durability.The main problem with this transmission at high power levels is the direct clutch.Our custom seperator plate removes flow restrictions that cause 2/3 upshift delay and friction element slip.Our revolutionary "3/2 Control Valve Delete" removes the infinitely variable orificing of 3rd accumulator oil to the servo release from the hydraulic system,and uses a single orifice.This is the real correction for direct clutch failure.Custom automatic shift valve body and governor combinations can give you the wide open throttle upshifts your vehicle needs.Calibrations can be made to allow wide open throttle shift points anywhere between 5000 and 6500 rpm's,without shift timing complaints at light or part throttle
  #17 (permalink)
Old 02-07-2013, 10:04 AM
I didn't go all out on my 200 4r for my nova. I was never going to race it. Givilng it hell with street tires didn't require alot of the extra goodies a drag car needs. I just wanted it to hold up to the 325hp i've got. I knew a stock tranny wouldn't, even the way i drive it. But with extra clutches, more preasure, better pump, better lower filter, ect., i knew that would work. It has worked great. My gear ratio with 3.73 is right. My next project is to pull the trany back and put in a higher stall converter. I know , even my friends don't understand why i didn't do everthing at one time. I wanted to make sure i didn't get the cart ahead of the horse. Mine was a little hit and miss. I found out that i had over drilled the seperator plate, so i changed it. Now that is rilght. Now that i've got miles on it, its time to change the convertor, and that will make it even better. My wife doesn't care how many times i've had the car up and down. I love it and it keeps me from bothering her. My second tranny was just for the fun of it. I know i'll never need it, but it was fun. Even my brother that is a ford guy, liked the combination. It makes a good street car with those gears, and overdrive for the car shows i like driving to.
  #18 (permalink)
Old 02-07-2013, 12:46 PM
I'll see how it drives first.hWhen I get it. I'm not a huge fan of 411s as every vehicle I owned all diesel but still has or had 410s and eats the mileage terrible. So I think I want the 373s again and this be mostly street cat alittle strip action but not much he said he has the car down to 320pounds
  #19 (permalink)
Old 02-07-2013, 01:01 PM
MentalMuffinMan
cars are only 3350 lb's anyways
  #20 (permalink)
Old 02-07-2013, 07:18 PM
oh haha i was told they were closer to 3600 on the internet.
  #21 (permalink)
Old 02-08-2013, 06:43 AM
MentalMuffinMan
at the dragway mine was 3350 lb and it's loaded, just no t tops(thank god)
  #22 (permalink)
Old 02-08-2013, 08:10 AM
Yea this one don't have t tops either kinda wish it did but they so leaky so I can live without
200-4R durability questions dirtyfingers Transmission - Rearend 9 12-13-2012 06:45 AM
200-4R Build Finally Begins! zildjian4life218 Transmission - Rearend 56 12-12-2012 10:02 AM
200 R4 can I build it myself? msc66 Transmission - Rearend 2 02-01-2009 04:56 PM
200-4r experts - build questions - Which core is best to build on? Warrant Transmission - Rearend 7 10-09-2007 07:36 PM
thm 200 questions 4dr77impala Transmission - Rearend 1 07-05-2007 08:51 PM
