200-4r shift kits - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2009, 08:06 AM
200-4r shift kits
Hello there i am looking to but a shift kit in my 86 monte ss which i beleave has the 2004r in it. some one told me i should put a rv shift kit in it what is this? I doint know much about transmissions so any ideas would help.Thanks Eric
Old 02-08-2009, 10:56 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
An RV type shift kit is usually a mild design of shift modifications.
What is the mileage - age of this transmission?
It is not advisable to add a shift kit to an older or weak transmission
Old 02-08-2009, 11:07 AM
fastcarsca
thanks for the input ya its an older one so i was going to have it rebuilt but would like to kick it up alittle any ideas besides the rv kit, or should i be looking for a different one. thks
Old 02-08-2009, 11:18 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
A TransGo kit;
200-4r HD2 kit will make that 200 trans hit good.
A larger servo for the band will help too. Couple of companies offer a 'super servo' set up for the 200 transmission.
Old 02-08-2009, 10:37 PM
I put a Trans-go shift kit, billet servo, 5500rpm shift governor, 0.500" boost valve, 3000 edge racing stall converter in mine. It shifts hard and fast. It chirps the tires on the 1-2 and 2-3 shift driving daily. When I get on the gas it will break loose easily in 1st, 2nd, and a few seconds in 3rd. Make sure you put an aftermarket tranny cooler on it. If your budget allows get a deep pan with cooling fins and preferably a drain plug and put in a 4l60e filter in it. It will position the filter lower so it will keep it submerged in fluid when you stomp it. This keeps your line pressure up. You dont want to drop line pressure when your pushing it hard.
Thats just my .02 cents. Even if the trans has miles on it I would recommend the shift kit and cooler. The slipping during slow stock-like shifting is hard on them and heats them up fast. Heat kills automatics. Also make sure you have the TV cable adjusted properly and if you're using an aftermarket carb get a TV correction kit from Bowtie overdrives for the carb you are using. I have one for my demon and it works great.
700r4 down shift question Jake_Dragon Transmission - Rearend 18 01-10-2009 03:29 PM
Tranny shift problems. chevcamz28newbie Transmission - Rearend 6 08-09-2003 05:52 PM
Tell me about shift kits... Guitarman Transmission - Rearend 6 04-25-2003 03:26 AM
Shift Kits PropanePower Transmission - Rearend 8 04-24-2003 04:34 AM
Shift Kits WayOutCat Transmission - Rearend 2 07-22-2002 08:06 AM
